1990 750 Sport Rebuild
Re: 1990 750 Sport Rebuild
Joe,
while you`re at it I`d also open the starter and check the brushes.
http://forums.ducatipaso.org/viewtopic.php?f=1&t=2573
Btw, seeing you pulling the rocker arm shafts. I guess you still have the old type. Newer Ducs (Supersport/Monster) have upper rocker arm shafts with a spring clip on (as far as I remember these are the same on 600/750/900), this makes changing shims much easier when adjusting valve clearance (just remove the clip and push rocker arm aside). I had mine swapped during the engine rebuild. No modification needed. I found mine on ebay for little money.
jpitz31
Post by jpitz31 »
Thanks G,
I pulled the starter in order to powder coat it, Now I will take it apart and check the brushes.
I ordered the rocker arm shafts, for $30.00 that is a steal.
Joe
1990 Ducati 750 Sport (mine)
2008 Piaggio MP3 500 (wife's)
My Ducati Blog site
Stupidity is not a crime, your are free to go ;-)
helge-seins
Post by helge-seins »
Hello Joe...
i would like to know...
your last Blog entry...
a few month passed by...
...hm, when will the story go on ?
:huh: :-(
Ducati 750 Sport `90 #750924
Ducati 750 Sport `90 #751918
Ducati 907 i.e. `93
Suzuki VX 800 `92
Yamaha PW 50
BMW e34 520i `93
BMW e34 520i `94
spaynenda
Post by spaynenda »
Joe, I'm also curious...and by the way I live here in Escondido. Could we be neighbors and not know it?
Make it a good day,
Sheldon
'88 Paso
'62 200 GT
'78 Laverda 3CL Jarama
'84 Laverda RGS 1000
