I notice that 'they' (Cagiva) played around with the air intake/ram height as the spare carb, off another Paso or SS of similar year, had shorter studs so plastic spacer omitted intentionally - unless this was the difference between 750 set-up and 900? You mention that one of the crucial mods is to obtain and fit the longer auxiliary venturis, I have the shorter ones at present so maybe something for the future
does the 'spacer fitted' set-up on a 900 actually show a worthwhile improvement in terms of performance or tractability or both? :beer
Ha Ha.. loving your humour - no, really!higgy wrote:does the 'spacer fitted' set-up on a 900 actually show a worthwhile improvement in terms of performance or tractability or both? :beer
Yes,both. It would be a simple thing to leave it out and prove it to yourself.........Once you get it running![]()
QUESTIONgiocast wrote:Kokusan it is.. for this cure, when I am well enough. Will pick up this thread in a couple of months all being well. Thanks again everyone
unless the Ignitech needs something different the correct ones would be the green 3 ohms Dyna coilscoils, Black version, alternatively a set of Dynacoils 5ohms
Ignitech can work with either of the two.paso750 wrote:unless the Ignitech needs something different the correct ones would be the green 3 ohms Dyna coilscoils, Black version, alternatively a set of Dynacoils 5ohms
I had a similar suspicion as longer time one or two guys posted about starting problems which were caused by a previous belt change. Either the engine was turned over during belt change or not all pulleys were set to their marks when doing the job. But, according to giocast that´s all ok.QUESTION
what if the FLYWHEEL got loose and the key is missing or broken?
you will always read 0 dregrees (or whatever is the "fixed" value), but it will be out of phase so, starting would be extremely difficult.
Honetly when it was time of chosing ythe coils i just took my Ohmeter meadsured 5.8 ohms from my old perfectly working coils and decided to get the 5.0paso750 wrote:3 ohm coils from Dyna, Andrews etc are just fine, nothing will happen. Every Duc shop or parts supplier sells them.
The only ones that are known to sometimes cause damage are the ones from Nology as their 3 ohm coils vary and some actually have a lower resistance.
I did run 2,7ohm coils from Silent Hektik for many years with the original Kokusan units although I wouldn`t recommend anyone to do so as these should only be used with their own programmable CDI unit. Still, I personally never had a problem.
the 3ohm Andrews coils are the yellow ones if I remember well.
