Paso 750 Dies in 1st gear
Re: Paso 750 Dies in 1st gear
Taken all in context and from the general condition of the bike,lots of corrosion and the odd noise I'd say doing most of the carbs is not enough. It is obviously running too rich. Take the float bowls all the way off, better yet remove the carbs check those needles and seats and clean everything,sounds too me like you have a jet clogged up or just general crap in the float bowl and most likely need to replace the needles and seats and any o rings sealing the jets to the carb body.
One other thing that just came to mind,check the floats especially if they are plastic they could have fuel in them.If they are metal they can be drained and resealed if plastic replace them :idea: :idea: :idea:
907pasonut
Post by 907pasonut »
cellardoor wrote:Im a new owner, just bought this 1988 Paso 750 and it appears to be well maintained.
Also this bike hase less than 6200 miles and appears to be all stock.
from judging at those photos...the bike hasn't been well maintained at all...if anything...neglected :dunno:
for a low mileage paso, looks like it has been left out in the weather for the last 10 years :huh:
dont let me discourage you...a bit of work and she will look good again :thumbup:
cellardoor?...are you into wine or something?
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
cellardoor
Post by cellardoor »
haha yes I am learning more and cleaning as i take it apart. compared to some other bikes/motors ive worked on, this one is clean enough. i know now its not all stock either
2001 996 SPS
1988 750 Paso
jcslocum
Post by jcslocum »
Check to make sure you have good fuel flow to the carbs. The the fuel pump still installed??
cellardoor
I have no fuel pump. And been reading other threads like this one:
http://forums.ducatipaso.org/viewtopic.php?f=1&t=95
I have cleaned the carbs and re tuned them and it took care of the idle problem. Bike is running well now! :lol: and idling just over 1000rev on start. It has stopped dieing during shifting and does not die when the clutch is in during stopping.
However still the choke kills the engine. The choke plungers were out of sync and are perfectly synchronous now so I dont know what else it could be. I was wonding how much should each plunger rise with a click of the choke? My choke seems to have 3 clicks with each click raising the plungers about 1/3.
2001 996 SPS
1988 750 Paso
Skins
Post by Skins »
Congratulations! It sounds like you're doing well.
The choke is there to help the bike run when it is cold, by enriching the mixture. It won't help the bike run when it is hot, and it should be retracted as soon as the bike will run without it. When the motor is warmed up, the choke is quite likely to kill it if it is applied.
cellardoor
ahhhh well the engine runs great! Choke is working. Clutch is slipping quite badly unfortunately. It will still get into gears at high revs but there is no power and lots of lugging. I will take apart the clutch to see what that problem is. Also when I bought this bike it had no speedo cable and I just installed one and the speedometer doesnt work, nor do the odometers.
Is it possible to take it apart the dash and try to fix the meters? Or should I buy a working replacement dash for 100$?
2001 996 SPS
1988 750 Paso
Skins
Post by Skins »
I would say if you can get a fully working dash for $100, you are a lucky man. Grab it!
cellardoor
87 engine in 88 frame
This plug is coming out of the back of the engine. The plastic cover has snapped and the wires are exposed. I have tried to slip a rubber hose over it but it was too thin
heres the wires from another angle
This is mounted where the fuel pump would have been. It splits the fuel line into a small line that runs into the engine (whats this for?) and then another line that splits and goes to each carb.
tail end mod.
No rectifier here
after market rectifier here
Here it is with all the fairings off. I will put up some more pics when I figure out the clutch
2001 996 SPS
1988 750 Paso
That is a vacuum type pump,should not be an issue as longs as it is working
could be the ground wire,best moved to the engine should be an empty bolt hole there already
No rectifier here
looks to me like you have a plehteraa of ground issues and electrical issues
shouldn't be there anyway but where is your ecm ?
need to take it out,could be just an installation order issue but most likely something is worn out or warped
then if you are lucky may just need a good clean :beer: :beer:
cellardoor
Yes Ive noticed the imaginative wiring but I'm not having any electrical issues at all; will get the clutch out tomorrow and hopefully I can figure out what the problem is...
2001 996 SPS
1988 750 Paso
That`s the neutral switch.
I wonder how good those electrical connections are as the connectors seem to have paint on them.
The clutch discs may be worn, check the minimum thickness in the shop manual.
About the dashboard, I actually never heard of one completely failing.
Good eye G, guess I need new glasses :lol: :lol: :lol: :lol: :lol:
