fuel valve 750 paso
bender
fuel valve 750 paso
Post by bender »
Hello all I am looking for a gas tank fuel valve for my 1988 paso if anyone knows where I can get the correct one please help. I also need a rebuild kit for my carburetor it is a 44 DCNF any and all help would be appreciated. :banghead: :banghead: :banghead:
ducinthebay
Re: fuel valve 750 paso
Post by ducinthebay »
Do you mean the fuel petcock?
bender
Post by bender »
Yes sorry for the confusion.
it may help if you`d add to your profile where you`re located.
bender
Post by bender »
I am willing to order the part because the closest ducati dealer is over 300 miles away, so where I am from should not matter. but i have added my location. Saint George, Utah.
This is an international group so yes where you are matters on the replies you need. :beer: :beer:
Try Ducati of Omaha,very helpful bunch with lots of parts most Ducati dealers don't want to bother with.
Email or phone
Turin
Post by Turin »
The factory petcock sucks. I replaced mine with a better one. http://www.mgcycle.com/product_info.php ... ts_id=1320 Make sure you get the one with the side outlet. the down outlet won't clear the frame.
1986 Guzzi BOTT Racer
Turin, as several other old bikes used this kind of fuel petcocks do you happen to know thead size ?
Turin
Post by Turin »
I don't know the thread size. I pulled the petcock off of my moto guzzi and matched it up against the stock petcock. Exact same nut, width thread size and count etc. The new petcocks fuel passageway looks larger/ flow more fuel, and the guzzi petcock has a much larger filter. It's worked great so far.
bender
Post by bender »
Thank you all for the help it is very much appreciated. :thumbup: :thumbup: :thumbup:
Turin
Post by Turin »
forgot to note, you'll want to leave it on the reserve position, or remove the plastic tube underneath the filter screen.
