hi fellas! ive been in the garage with the wiring diagram pdf download (thanks whoever great to see better!)
Ive looked and learned that my alternator has two yellow one red to the diagram gree and red.
the connector im talking about in my regs and wires post is the no.6 instrument connector this joins the regulator ok?
since taking off the original two greens are left these are ok because the are joined together(one question answered)
one pink to dash(charge light ?)
now one red from solenoid? can anyone tell me is it a problem ive left it and it doesnt connect to anything now!!! it is in the connector-should i remove it could this be why my batterys are cooking?
ive also found i had a blown fuse the one that is in the upgrade red wire it has made the fuel pump work but i still have no dash lights horn etc-could something else have blown the solenoid maybe?
waiting for reply....desmodve.
p.s sorry i forgot also since taking off the old reg the two green are ok joined but they did also wire up to the regulator too!!! but not now with the rr51 electrex.
thosecrazy wires!!!
- year: 1986
Re: thosecrazy wires!!!
Ok Dave, I think your main problem is that the black and green wire that went to the old reg,needs to go to an ignition source,some where that is live when the ignition is turned on.NOT TO THE BLACK AND GREEN WIRE ON THE NEW REGULATOR.You can test this by touching it to the solenoid wire and seeing if your dash lights up,but you can't leave it there as it will be live all the time and flatten your battery.
Join the two yellow altenator wires together and connect them to one of the generator wires on rr51.
join the red altenator wire to the other generator wire on the rr51.(the gen wires should both be yellow or yellow and white ?)
join the pink wire and red solenoid wire together and connect to the red wire on rr51
connect the black and green wire on the rr51 to the battery negative terminal or a good earth.
I think the blue wire has to go to the skinny white wire on the rr51,not 100% sure though.
This information should be correct,but please use common sense when hooking it up as I won't be responsible for you melting your loom.
Jay.
I was just looking at the wiring diagram to see if I could spot somewhere for you to tap into the ignition wiring,I assume you have mounted the regulator under the seat.If so,I think one or more of the fuses should go live when the ignition is turned on ,check with a test light,which one and tap into the wiring coming out of the correct fuse,make sure that you are on the correct side of the fuse though so your modification is also fused. J.
- year: 1986
Disregard what I said about the black and green wire,I got my wires crossed,it does go to the black and green wire on the rr51. J.
