New here
- Derek
- year: 1994
New here
I'd just like to introduce myself to the forum as a new member. I have recently, 2 weeks ago, bought a 907ie to accompany my '03 ST4s ABS that I've had since 2005. The 907 was registered in the UK in March 1994 and is one of the last, with Goldline brakes. It's red and is completely standard and original. I've been into Ducatis since the early seventies and have plenty experience with bevel twins and singles and belt twins, 2V and 4V. Electrics are my speciality but I'm equally at home with any mechanicing. I'm looking forward to getting out on the 907 in the coming year when the weather improves.
- JoKing
Re: New here
Wow. Another nice bike.
An me? I am spending loads of time & money, trying to bring mine into an equal condition.
As you are an electrics specialist, can you tell me where to get the dash-connectors from?
Johannes
Johannes
86` Ducati 750 Paso
96` Cagiva 750 AC Elefant
86` Ducati 750 Paso
- JoKing
Re: New here
Can you give us the frame number? Currently, mine is the last known, i think...
86` Ducati 750 Paso
86` Ducati 750 Paso
Re: New here
JoKing
Which ones you need? I have some although they are not new on my donor 906
- JoKing
Re: New here
The ones that connect to the rear of the dash, because i am building a mixed 907/ST3 Harness....
86` Ducati 750 Paso
86` Ducati 750 Paso
- Derek
- year: 1994
Re: New here
Ha, I'm good a fixing electrics but not necessarily at sourcing bitsJoKing wrote:As you are an electrics specialist, can you tell me where to get the dash-connectors from?
Frame number is ZDM906P12*001958. Not the last but within the last 80 or so.JoKing wrote:Can you give us the frame number? Currently, mine is the last known, i think...
Re: New here
have all 3
Re: New here
higgy, Johannes, some others and I are looking for new ones to build a new wiring harness. The plastic connectors can be resued that`s not the problem but the crimped contacts need to be replaced. Finding those is not so easy.
- JoKing
Re: New here
That`s a late one, but not one of the last. Mine is 2285, when i have it in mind correctly... How many were built? 2303?Derek wrote:Frame number is ZDM906P12*001958. Not the last but within the last 80 or so.
@ Higgy: Is it possible to get them here, mabe with as long as possible cables left on the connectors?
@ G: Yeah, that would be the preferred way...
86` Ducati 750 Paso
86` Ducati 750 Paso
Re: New here
I can send them out. I can also cut them as long as you need except for one that is already cut short.
I'll get you a pic and pm it to you ,we'll work it out
Re: New here
Pm on the way
Re: New here
Most are similar to Delphi terminals,I have been trying to figure out exactly who was sourced for the original terminals but yes G you are correct in that they seem to be hard to find and the crimpers needed are also not cheap. Crimpers are from time to time found on ebay for much less than new.
New crimpers are typically in the 100 to 300usd range, ebay 25 to 35.
Delphi does have a catalog you can download and I am in the middle of going thru it now,400+ pages so it will take a while.
Both of you being in Europe might be able to find out who Fiat uses to source their terminals,
Fiat is just now coming back to the US so info is sketchy at best.
I did find a suitable connector and terminals for the regulator from Electrosport The kit was 6 bucks and came with the connector and terminals,nice plated terminals and the connector includes a locking tab
BTW the terminals for the dash are side plane type,double side plane I think
One possibility is an AF Female Terminal UNsealed #12131448 from Delphi
Re: New here
higgy, those are not the ones. Check the terminals. They look somewhat like this
Re: New here
Very clean bike, congrats!
Can you post a close up pic of the top case mount, near rear pegs?
Re: New here
Hi Derek, nice looking 907!
The standard pipes do look good!
How many km`s?
Is that a battery breather hose attached to the swing arm?
I eneded up buying a deka sealed battery to get rid of any battery acid problems.
How many km`s?
