Time flies
- Witzie
- year: 1989
Time flies
Time flies when you're having fun, certainly when you are riding a Paso. But the clock on my PASO dash is taking this too literally, it's running way too fast. An hour takes about a minute to pas, you can see the handles moving. Anybody seen this before? Maybe a simple solution?
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994, Kawasaki ZZR1100 1993, Ducati Paso 906 1989
Re: Time flies
slow down witzie!
1990 906 paso red and white
1991 906 paso black and gold
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
- scimmione
Re: Time flies
Time and speed are relative: The faster you go, the more time slows. So, go faster, your clock will slow down!
Seriously though, under Parts Interchangeability Listing = http://forums.ducatipaso.org/viewtopic. ... ngeability you'll find lots of good fixes and alternatives.
The Paso clock can be replaced by using the printed circuit board from Fiats like the Mirafiori, Tipo and Jaeger.
Wish I'd bought the 990 years ago
Re: Time flies
surely a volt meter or something would be more useful than a clock???????????
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
1997 ST2 red
1962 rover 95 p4
1997 iveco daily
Re: Time flies
Bugger me ! some people are never happy
mine dont work at all . I bet yours tells the correct time more often than twice a day
Re: Time flies
Check out the clock faq
all you need to do is replace a resistor
- Witzie
- year: 1989
Re: Time flies
Winter is over in Holland so i took my Paso out for a spin. As my garage is a bit damp i had some electrical problems so i cleaned all the connectors which solved all the electrical problems. Guess what, the clock is also running perfectly!
Re: Time flies
Not bad for somewhere thats mostly below sea levelWitzie wrote: As my garage is a bit damp!
- Witzie
- year: 1989
Re: Time flies
my house is build just over sea level, must have been rising damp!
