Does anyone know of a replacement for the turn signal flasher, or where I can find one? Mine quit working, and the only "local" (about 40 miles away) Ducati dealer doesn't have any knowledge of older bikes or their parts. I gave him the part number from the micro-fiche that I downloaded from this site, but he said that he couldn't get the part.
Any help will be appreciated!
Turn Signal Flasher Replacement
Hello jfiore,
ain't that a simple flasher relay? Like other's used in cars?
Even if not, here are the standard pin assignments, so you can fix the problem by changing the wiring using a standard flasher relay like Bosch or Hella or something....
49 flasher in
49a flasher out/ flasherswitch in
49b 2. flasher out
49c 3. flasher out
C 1. controllight flasher
C2 2. controllight flasher
C3 3. controllight flasher
L flashlights left side
R flashlights right side
L54 Out for combined flash-/brakelights at Trucks and
Trailers, left
R54 Out for combined flash-/brakelights at Trucks and
Trailers, left
Even look at the "pincode" of the original relay and transfer the wiring to the new one.
Hope you could use this!
Greets,
ducster
49 flasher in
49b 2. flasher out
49c 3. flasher out
Trailers, left
Trailers, left
Greets,
ducster
