It's been a struggle to try and get my Paso to idle correctly. Jayh has been a great help. Above 3k and under throttle the bike runs great. It's just at idle and after running cool start that I have issues. In order to get the bike to even run I've had to back off my A/F screws about 4 1/2 to 5 turns which is way too much. I've also tried a couple of different jettings per my discussion with Jayh to see what happens. From cold it starts right up with the choke but after it cools down it's a bitch to start. Well, today I decided to tear the carb apart again thinking that maybe I missed something and I found a crack in the venturi where the A/F screw pokes through! When I measure the difference between the good one and the cracked one the cracked one is about .06mm larger at the exit. It looks like someone either dropped the carb on the screw and the force pushed on it and cracked it or they cranked way too hard on the screw and split it. Any body have any suggestions on how to fix this? I don't have the money for going to dual Dells or anything like that.
Also - It also looks like there is a crack around the venturi but it appears that is a casting mark. The venturi is not out of round.
