ECU Test Light
nickta
Re: ECU Test Light
Post by nickta »
Morning.
Got the parts and built the LED test light. Haven't found a suitable plug for the test socket under the seat, so the cable has boot lace ferrules on the end which slip in nicely. Plugged it in, tested the LED. No problems. Put it in test mode, started the bike which promptly did the right thing and stalled after start up. LED flashes away, indicating there was no RPM. It must work....
Cheers.
Nick.
Re: ECU Test Light
there`s currently one for sale in the Netherlands
http://www.marktplaats.nl/a/motoren/ond ... ousPage=lr
Derek
Re: ECU Test Light
Post by Derek »
Anyone got the circuit for the test light?
907pasonut
Re: ECU Test Light
Post by 907pasonut »
nojapan wrote:Image
nojapan has the best circuit diagram, looks simple enough, one light emitting diode, one 1000ohm resistor, a two way switch and a battery, even without a plug the connections are simple...personally I wouldn't bother building one
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
ducbertus
Re: ECU Test Light
Post by ducbertus »
Hi G...
thanks for bringing it under my attention.
placed a bid. see what will happen.
Bertus
Re: ECU Test Light
