907 IE lift handle
- redpaso
- year: 1989
- Location: Land of OZ (traylia that is) Troy Bayliss Country
Well I did it in the shed the other night ("The Craig manouvre" that is) & I am very impressed @ how easy it was to Perch "the Mistress". I don't think I will ever get off to put her on the stand again.
Skins, I hope your recent mirror damage is not the result of you practicing this technique
Redpaso
- Skins
Nah, it was contact with a wall on my driveway, as a result of brake failure. I'm not sure exactly why the failure occurred, because the brakes (front) had been good for a few days after I recently replaced the fluid, and after the little accident, they were even better! I think maybe there was a little air left in the system after I replaced the fluid (although I bled the system as carefully as I usually do), which formed into a largish bubble, which then worked it's way into exactly the wrong place (near the master cylinder piston) at the wrong time (me heading down the driveway).
Anyway, I've had expert advice that I should be able to fix the pod with Araldite, so that's not too bad. I haven't tried to do the 'Craig' yet, but I will get around to it. I'm glad to hear it worked for you!
bill_daf
