some time ago we had a thread here regarding some special heavy duty iring/harness for better engine-starting behavior.
I can`t find it now.
Who knows what i mean?
Johannes
hi Bertus,ducbertus wrote:Hello Johannes,
upgrading starting behavior is not difficult.
1) battery in perfect condition?
2) connectors of starterrelais not corroded? the rubber booth is famous for collecting water, ergo soaking the relais
3) startermotor itself in good condition? brushes, connectors
4) improving the leads from battery, everything to starter moter and very important from engine (rear side left) to the battery.
I use grounding leads from welding equipment. this is very flexible and ment for high current use. cross-section should be 16 mm2 of 25. for this I bought a high pressure hydraulic crimping tool.
5) you can replace the 70 Amp Hitachi relais by an 150 Amp relais of a tail gate lift unit. ( costed my a mere € 20) A friend of me used this relais on a 1000S2 bevelhead twin and was stunned by the result.
6) further I've an article from Laverda-guys replacing the 2 brush stator plate by a 4-brush plate. combine this with an additional internal ground lead out of the starter motor and you'll end up with an 907 starting up before you can press the starter button fully.![]()
Bertus
On the 750 of mine the power lead to the coils and electronic control units first passes through the solenoid, on to the start button, and then off/on/off switch. That's why when the two latter switches were grunged up the spark was too week to fire the bike and it kept fouling plugs, though it mostly affected the forward cylinder for some reason. It was sometimes starting but just running on one cylinder. Check you schematic (I'm not familiar with the 907IE), unless you've already cleaned the switches. If your coil feed takes the same route through the switches and a 6 pole connector first as in the 750, any of those may be your problem.JoKing wrote:I got a brand new battery in there.
And it started very well.
But now, it turns the crankshaft, turns and turs and turns, i`ve got sparking plugs, wet plugs, but it dos not fire up
