It is currently Sun Apr 18, 2021 7:52 am
 Post subject: What engines fit paso frame?
PostPosted: Tue Jan 29, 2013 11:46 am
Hi all, I was thinking of doing the mikuni carb swap on my 906 but its gonna cost at least a grand to do the conversion and with the other repairs I've got to do...and will have to do in the future (59000km on the clock) Ill be up for a couple of grand at least.
Sooooooo I was thinking about dropping a low km motor in it from a wrecked monster or 900SS and solve all my problems. Does anyone know if one of these will fit and if there is anything on the market in the UK (as anything Ducati over here in Oz is overpriced)
Lane
89 Dark Blue 906 Paso
 Post subject: Re: What engines fit paso frame?
PostPosted: Tue Jan 29, 2013 5:05 pm
how can a Mikuni conversion cost a grand and why swap the motor and spend money for that if it`s still running ?
Ducati engines are robust if they are regularly serviced and driven warm. A high milage does not necessarily mean it`s going to break down at any time. There are Pasos here with over 100.000km on the clock and a friend`s 888 has 120.000km and is still running strong.
The Paso motor has a narrow swingarm mount. Hence if you use one from a SS or monster the bosses on the engine need to be machined to fit the Paso swingarm. Also the thread on the front cylinder needs to be modified as the Paso uses a much larger bolt.
G:
PostPosted: Tue Jan 29, 2013 6:46 pm
Hi G, $1000 was the quote from the ducati shop in my area. They did say I could save some money by trawling eBay and get items myself and have them do the job. I'd like to do the conversion myself but don't think I have the expertise. Is there much to it? Maybe I should look on youtube for a tutorial :D
It's good to know these engines are reliable and robust, but the big ole I bought mine off didn't really look after it very well so I'm always expecting failure. I figured buying a low km bike, I could use what I need and sell the rest to recoup some costs.
Lane
PostPosted: Tue Jan 29, 2013 7:07 pm
If I did do the conversion, what do you recommend...mikuni, delorto, keihin? And what size would I use?
Lane
PostPosted: Tue Jan 29, 2013 9:50 pm
This may nudge you in the right direction hopefully
viewtopic.php?f=2&t=3536&hilit=906+carb+conversion
PostPosted: Tue Jan 29, 2013 10:26 pm
Simplest way is some carbs straight off a 900ss/cr or Monster - you need the inlet manifolds, the inlet manifold rubbers, the twist grip and the throttle cables. You'll also need some sock type K&N or pipercross type filters.
Clean the carbs, mess around with the jets, bolt it all on and then go for a ride.
Its been a while since I did my 750 (ten years or so) but its really not hard to do.
If you want to do the full job you need to get the fibreglass out and modify airboxes (or build a full carbon fibre custom one) but thats beyond my skill/patience level and best left to guys like G to get right !
In fact most of the bits you want are here
viewtopic.php?f=4&t=5807
PostPosted: Wed Jan 30, 2013 6:11 am
Cool, thanks guys, helpful as always. I'll chase it up and have a crack at it myself :thumbup:
Lane
PostPosted: Wed Jan 30, 2013 8:25 am
To answer your question. If you`re on a budget there`s about no way around the Mikunis. Ducati SS & Monster (600, 750, 900) used them as did the Yamaha TDM900 and TRX850.
Dell ortos are rather expensive. Keihin FCRs and Mikuni TDMRs are in a totally different price category.
There may be some standard Keihin carbs that can be fitted. However the advantage of the Mikunis is that you can get all required parts to mount them easily and also jets and needles are no problem.
PS: check your pms
PostPosted: Sat Feb 02, 2013 8:50 pm
The other good thing about using the Mikunis from another Ducati model is that;
1. they are pretty reliable and steady. Not many bad thing written about them except that they were originally tuned to pass emissions tests.
2. you don't have to re-invent cables and throttles and such. All pretty cheap on e-bay or from a bike yard.
3. They are the cheapest option. I bought a set with manifolds from the local classifieds for $50.
4. Easy to modify, as there are plenty of kits to rejet the carbs, and lots written about it. (not so much on this site, but many others) Get a Stage 1 or Stage 2 kit and the 906 should run pretty damn good, all the time.
Not the highest performance option, but probably the best option for good usability, especially around town.
Can't say what you need to do for an air box. Can you modify the original, or will an SS or Monster box fit? I'm sure somone on this site has made this change.
PostPosted: Sun Feb 03, 2013 12:25 am
model: other
G'day Lane
These guys may be able to help you, be it engine or carbs
http://www.motorcyclewreckers.com/contactus.htm
02 9748 7400
Speak to Ben or Joel (owner), they are currently wrecking a few various Monster's and other models at the moment, and may have what your chasing at the right price, always worth a try.
Peter
PostPosted: Sun Feb 03, 2013 1:29 am
Excellent, thanks guys. I've just bought a set of mikunis from Dan (ex TRX850) so will be fitting these when they arrive. I've also got twist grip, cables, 900 inlet tubes, just need pods, new fuel lines and some patience. I've read all the threads so hopefully won't be asking already answered questions :beer:
The wreckers will come in handy for other things needed tho. so thanks Peter.
Lane
PostPosted: Sun Feb 03, 2013 10:01 pm
For what I've seen carb conversions going for you could piece together F.I.
PostPosted: Sun Feb 03, 2013 10:42 pm
You could always go for a megasquirt I guess !
A lot of work though with getting all the right sensor feeds in place
