see here
http://forums.ducatipaso.org/viewtopic.php?f=3&t=5562
Making a good thing better...
- model: other
- year: 1986
Re: Making a good thing better...
Ah, thanks. So I was wrong but a bit right too.
- 907pasonut
hi du907, I've started a thread on that a while back, its something I'm trying out, my belief is that the resonance inside airbox can give false signals and cause havoc with the computer between 2.5 and 3.0k rev range...not sure if it works yet, but from a short ride around the block looks promising so far...du907 wrote:pasonut
In the picture of the adjustable cam pulley, what is the copper pipe coil tube, on the right, going into the air box?
Never seen that before.
du907
...just noticed, thanks for that G
Cheers Claude.
'92 907...numero 2046
'92 851...in progress
If only it was that easy
- 907pasonut
I can only try...even if it doesn't work I won't fit the FBF chip back onhiggy wrote:If only it was that easy![]()
Cheers Claude.
