Is the bottom color (the dark part) on the fairing the same on the red, blue and white Paso's?
Anyone have color codes for the Paso colors?
Colors
Re: Colors
plasmid,
I have owned my 750 Paso since July 4th weeked of 1987. I do not know of a paint mumber.
Locate a automotive paint shop with a spectrophotometer. The spectrophotometer is used to match paint with a color sample.
Take a sample part off your bike maybe to a side faring. Go to the paint shop they will scan the part with the spectrophotometer and create a color mix that matches your bike. This only takes a few minutes.
In the USA a pint of custom made paint will cost me $80.
This paint is flat, so you will also need a clear coat cover to create the finished look.
Good Luck !!
Best,
20yearowner
Good Luck !!
Best,
20yearowner
- davidbartoli
Re: Colors
The original Paso750 red (it was changed after 1988) was done by LECHLER S.p.a.
www.lechler.eu and the correct name was "Ducati rosso paso". I don't have the code, sorry but I found a carpainter a few years ago with a catalog still showing that color. I got a 1/4 gallon and it matched perfectly.
Re: Colors
Guys, all this info is in the FAQ
