Its Sprag time....
Re: Its Sprag time....
Don't you hate it when there are two #2 in a picture! The #2 I am on about is between #3 and #5.
That #2 is the same kind of washer. As you can see in the picture the tophalf shows the 888 SP5 which has a narrower rotor hence on the inner side a spacer and a second belleville washer. The 888 Strada doesn`t have that and neither the 907ie.
