Here are a few pictures of bike, the woman, and Frankenstein Airbox that came with the used motor
Muchas gracias,ya comprobe que si,que tare especificaciones de monster 600,le he cambiado como tu dices..para buscar las especificaciones de la 900,o sea:cambiar chicles y agujas(las agujas no las he cambiado,tengo unas 5cj y la 900 ha de llevar una 5c19 y su correspondiente emulsionador).paso750 wrote:that`s not my bike above![]()
If you have a Mikuni from a 600 Monster and just put it on the Paso that explains a lot.
Someone said that the passage ways in a Mikuni from a 600 Duc are smaller than the ones in a Mikuni from a 750/900.
I don`t know about that but the standard jetting is different on 600, 750 and 900 engines.
750SS:
main jet: 140
main air jet: 70
needle jet: Y-6
Jet needle: 5C19 - 3rd notch from top
Pilot jet: 37,5
Pilot air jet: 60/1.4
900SS:
main jet: 140
main air jet: 70
needle jet: Y-2
Jet needle: 5C19 - 4th notch from top
Pilot jet: 42,5
M600:
main jet: 132,5
main air jet: 70
needle jet: Y-2
Jet needle: 5CJ1 - 3rd notch from top
Pilot jet: 37,5
Pilot air jet: ?
You will have to remove your Mikuni and disassemble it to check the complete jetting you currently have.
To get to the needle jet you remove the nut marked red and push it out (with the grey plastic part)
With the K&N filter you`re using and the Gio.Ca.Moto 2in1 exhaust neither the 750 nor the 900SS jetting will be completely right and can only serve as a starting point. I guess I`d use the 900SS jetting for reference in your case and go from there, so with a larger main and pilot jet and new jet needles.
Important to prevent leak air of course is to use good rubber boots (the connections between the Mikuni and the carburettor manifolds), to use paper gaskets between the carb manifolds and the cylinder heads and to close the the hose nipple connections on your carb manifolds if these are not used (with a small screw and copper washer).
