New Project 907 evo
- persempre907
Re: New Project 907 evo
Keep that wonderful F4 as is...
Don't listen to Mr. G!!!!
- Bock900r
Spend some time at my friends Bikeshop to work on the Project. I have enough overhours to spend some time home
Bought some time ago the yellow fairing, Tank, all Yellow.
Got all the cables and electric connections done. The Fuse holder is at the moment hanging down, need a good place
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
- Bock900r
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
- Bock900r
Oel change and may be change the volume is planed after everything is done. Your values are a good point to start with.900streetfighter wrote:That's looking good Bock, that bike will fly. Suggest you change the oil in multistrada legs, I used 600mm of sae7.5 per leg as per manual. That reduced the travel significantly, before I did that I had clearance issues with tyre/radiator. I raised the rad 20mm also. I have raised my legs in the yokes by 15mm now.
I placed the the Cat-Box under the bike
I will use a Akrapovic Shorty as Exhaust
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
Your rear arm looks about 50mm shorter looking at footrest/tyre position.
Probably be a hairy ride with 4v power.
- Bock900r
I will measure the lenght from the swingarm bolt to the center of the wheel tomorrow900streetfighter wrote:Your rear arm looks about 50mm shorter looking at footrest/tyre position.
Today I shim he swingarm, install the rear break, tight the srews for the Kat Box
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
- Bock900r
From the swingarm bolt to the center of the wheel is it 520mm to 540mm
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
907 arm is about 585mm from ctr of pivot to ctr of adjuster slot.
- Bock900r
Change the Belt's today, fill the Tank. Push the button - running
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
- persempre907
Bock900r wrote:Change the Belt's today, fill the Tank. Push the button - running
Let us know after the first flight!!! That bike will not run, she'll fly!!!
The way Rudiger is cracking on that will be soon .
- Bock900r
I took the Original Cockpit from the S4R. Ididnt want to try to convert it into the Paso cockpit. Too much Electronik and too many wires
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
What yokes have you used Rudiger?
Keith.
Keith.
- Bock900r
I use some connection points from the Cockpit holder and use a aluminum plate to block the view and hold the cockpit
Rüdiger
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
__________
84 GPZ 900R
84 GPZ 900R
86 GPZ 900R
88 GPZ 900R
888 SP4
907ie Black
907ie Red
907 evo (project)
998 Matrix
998s FE
V50 Monza
MV Agusta 750 Evo2
ZXR750RR-K
ZXR750RR-M
