If yes, how does it compare to the Surflex brand. Thanks
Not sure I need a full kit as such but all the steels have some wear and grooving and the thick plate has almost no friction material left hence I think my only option is a full kit. Was tossing up just the frictions or the Barnett kit but concerned I still won't get an "as new" clutch. Interesting the hub tooth count is the same, I' sure I'd seen talk on ms that the later ones differed in that respect. Obviously some of the later steels would work if you could buy the thick one sided one separately but I haven't seen it anywhere and by the time you get it if you could then a later kit the cost probably ends about the same.Nunodeo wrote:Sorry I forgot to mention that I had to use my old outer thick one sided steel/friction plate. As far as the steel plate tooth count it's the same. When I called Barnett they did not list a kit for the older 750s. However kit#306-25-40002 fits a lot of Ducs. with dry clutches, like the 748, 750S, 851, 888, 900SS and so on. Because you need a full replacement set this would not be the best kit for you.
