Hi.
Can anyone help med with the rubber cover for the belts. It is the one for the horizontal cylinder.
Ducati partnumber : 23510061A
http://www.stein-dinse.biz/Komplettange ... :8598.html
Rubber cap hor. cylinder - 906/907
Re: Rubber cap hor. cylinder - 906/907
I had to rebuild mine as it was cracked around where the screws go in . I would have a look at the later model 2 valve motors , I aint sure ( G probly knows
) but I would think that the later SS motors would have the same piece on them and it may be available under a different part #
http://www.oiltalavante.com/DUCATI-23510061A/en . I just had a quick look and this lot have one for 15 euro , I have no idea where they are
H
H
Hi.
I have a order pending at them, but they are not able to get it. Have also tried Stein Dinze but no luck.
I will try to look at the other models to see if they could fit - thanks.
- Derek
- year: 1994
it's the same part on all the 904/944 engines - SS, Monster, ST2
actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be.
I have ordered this and will try a small modification. I will report back if it works...
- Derek
- year: 1994
On further investigation I have to concede that your rightpaso750 wrote:actually it`s not http://www.stein-dinse.biz/Komplettange ... tyPhoto/0/ but if that tongue is cut off it probably will be.
The Monster and SS models use that cap, part no 235.1008.1A
The 906, 907 and ST2 use the cap without the tongue, it's part no. is 235.1006.1A
The ST2 part should be readily available.
