Mufflers
persempre907
Mufflers
Post by persempre907 »
I would want to mount the Monster mufflers on my 907.
But I fear damages to the motor.
Can you tell me if it's possible?
Ciao.
DesmoDog
Post by DesmoDog »
Only way I can think of that it could do real damage to the engine is if it leaned it out quite a bit. I'm not familiar with the mufflers you're talking about so can't really say if that's likely.
I'm not sure if there is a Power Commander or some such thing available for the 907, but that would be one soultion to any problems, assuming you can find someone to develop a fuel/ignition map for it then.
If the mufflers you are refering to are a straight through, "race" can design, then you could get a stage one chip from one of the typical sources and be fine.
-Craig
Finnpaso
year: 0
Post by Finnpaso »
Buy FIM chip and also FIM additional memory board to save all changes to fuel/air map, then You have enough good things to put whatever pipes to Your 907IE :thumbup: P7 ECU need memory board,if You change map and WANT TO SAVE it, if ignition power is turned off from U bike. Read more from FIM sites on web.
907IE -91 red/metal grey
907IE -91 red
persempre907
It seems to me not easy.
I will try to read something about FIM.
Ciao.
Finnpaso
year: 0
Post by Finnpaso »
If You change from normal pipes to open ones, You HAVE TO adjust fuel/air mixture to more rich, or Your exhaust valves CAN burn!!!! I have seen some such cases, so be careful, what You do to Your baby :thumbup:
907IE -91 red
persempre907
It's so!
But the OEM monster mufflers would not be open.
What you think about it?
Hello baby.....
Finnpaso
year: 0
Post by Finnpaso »
So, WHAT does it help if change another set of resistive mufflers??? I would change to open ones, open K & N with snorkels away, new FIM chip (&FIM memory board)with tuning to get more hp's from engine... :cool: At least i did that and also some more.... ST2 cams, ported heads, 1 kg away from flywheel, STM 48 teeth light clutch, bigger rear sprocket.... Btw, quite light front of bike these days during acceleration :thumbup:
907IE -91 red
persempre907
Hi Annti,
for me the 57 kw of 907 are enough!
I'm very still driver after last tumbles!!!
But then... I would buy a Monster S4...
Maaaaahhhhhhh.
Ciao.
F
Finnpaso
year: 0
Post by Finnpaso »
.... and i bought ST4S ! :thumbup:
907IE -91 red
