instrument panel removal 907ie
Hi everyone new to the forum so heres my problem, I have a 907ie from 1992 which hasnt ran for 12 years after a week of cleaning injectors new in tank pipes I managed to get her going well, but i noticed the 3x rubber support dampers that hold the instruments to the frame had fell apart, unluckily for me one had left a blind lug in the panel so I need to remove it to extract the said lug. I have removed the speedo and rev cable and the multi wire clip connectors but there is a wire on the right hand side if looking from standing in front of the bike (rear of instruments) left side of panel when sitting on the bike that i am not sure if this just pulls out or is there a special method of removal, I don't want to force it in case I break something as parts are getting difficult to come by. many thanks for any help with this re Alistair
Re: instrument panel removal 907ie
Alistair, that`s the cable to the odometer zeroing knob as the manual calls it.
Don`t remove the cable from the instrument panel. Just remove the flat knurled nut from the zeroing knob and remove the complete instrument panel with the cable.
Thanks for the advice on the cable its much appreciated re Alistair
