Brake Discs 907 early version (300mm)
angelix
Post by angelix »
I have been scavenging the net trying to find a souirce for the original 300mm didcs used on tghe early 907s
I did find some alternative parts from other brands (the same discs fit Guzzis, Yamahas, Cagivas and may others) but nothing from Brembo.
I do gave the original set that came with my bike but they were replaced because of vibration with a new set from DISCACCIATI
I was wondering if anyone knows of a potential source of the old brembos?
ducinthebay
Re: Brake Discs 907 early version (300mm)
Post by ducinthebay »
Originals are pretty hard to find. First year 851 had them also. But between those two models, there were only a couple hundred bikes built to begin with. Finding them 20years on will be tough.
The Yamaha YZF rotors work pretty good, as I ran them for years. I later found a set 300mm Brembo cast iron which are as rare as hen's teeth. Took me 5 years of searching e-bay.
Other alternatives are the newer rotors from some of the 620 models (cheap on e-bay), and also aftermarket rotors from EBC, Pro-Lite, or the ones you currently have.
Phil
angelix
Post by angelix »
I have already found all the "compatibles" and on ebay (Italy mostly) there are also few Brembos that should be compatible.
I checked with Brembo and they don't show the 907 rotors in their "listings", but I know that others they have should be exactly the same thing, it is just unfortunate that they decided to take them of their listings only because the bike model is over 20years old making our lives difficult.
According to my info, the BREMBO 78B408A2 , which is the same of several Yamaha models) should be compatible 100%, but the design of the carrier is different (same fitting , different color and cut-outs) so before committing I wanted to look around hoping I could put my hands on a set of cast irons with the same design (or similar) of the original ones.
I still have my original rotors and i was also looking ito finding the overhauling kit (was it Spiegler who use to make them?) but it seems that they have disappeared from the market (apparently they do only BMWs)
Anyway I will keep looking into this and if I find something I will update this post.
in the meantime here is a list of correspondences that MIGHT be useful:
YAMAHA part# 4HM2581T11
APRILIA part# 8113500
CAGIVA part# 800094980
DUCATI/GUZZI part# 49240051A
APRILIA - 250 - RS 250 - 1995 / 2003
CAGIVA - 125 - FRECCIA 125 C 12 - 1989 / 1991
CAGIVA - 650 - RAPTOR 650 - 2000 / 2007
CAGIVA - 650 - RAPTOR V 650 - 2000 / 2005
CAGIVA - 1000 - RAPTOR 1000 - 2000 / 2007
CAGIVA - 1000 - RAPTOR V 1000 - 2000 / 2006
CAGIVA - 1000 - RAPTOR X 1000 - 2000 / 2005
CAGIVA - 1000 - RAPTOR XTRA 1000 - 2000 / 2004
DUCATI - 900 - 900 SS SUPER SPORT - 1988 / 1990
DUCATI - 900 - 906 S – 1989
DUCATI - 900 - 907 PASO IE - 1990 / 1991
MOTO GUZZI - 1000 - DAYTONA 1000 I.E. - 1991 / 1994
YAMAHA - 125 - TZ 125 COMPETITION - 1996 / 1997
YAMAHA - 250 - R 1 - Z – 2000
YAMAHA - 250 - TZ 250 GP - 1996 / 1997
YAMAHA - 400 - FZ 400 – 1996
YAMAHA - 400 - FZR 400 R/RR//RRS - 1989 / 1992
YAMAHA - 400 - SR 400 - 2002
YAMAHA - 400 - XJR 400 R - 1995
YAMAHA - 600 - FZR 600 – 1989
YAMAHA - 600 - FZR 600 R - 1990 / 1995
YAMAHA - 600 - FZS 600 FAZER - 1998 / 2003
YAMAHA - 750 - FZ 750 GENESIS - 1989 / 1992
YAMAHA - 850 - TDM 850 - 1991 / 2001
YAMAHA - 850 - TRX 850 - 1995 / 2000
YAMAHA - 1200 - FJ 1200 (NOT ABS) - 1988
