Joining the club - MBD
- year: 1989
Re: Joining the club - MBD
I am using Evans waterless coolant and it works great. It negates the need for an expansion tank as it doesn't expand or give off steam. As these tanks are getting old and brittle it's prob a good idea to do it now rather than after a roadside breakdown due to coolant loss
Of course, the CBR600 radiator cap conversion should prob. be done first to take the tank out of the loop.
Lane
89 Dark Blue 906 Paso
Hi Phil.ducinthebay wrote:Gents, I heard music. 907 music.
Now, I'm going to remove those 14 year old tires that look almost new. Anyone have recommendations on what to put on there? I've been a bit of Pirelli fan on the ST4s and the Sport. Should I go with the 170 or is there an advantage to go with a 180 rear?
Should I just assume the coolant is past its prime and change it all out?
Phil
Forget the 180 section. My 907 had one fitted, and it rubbed up against the guard at full suspension travel (the shock was stuffed at the time). I put Bridgestone BT-023 GT's on the bike a year or so ago. They have a slightly stiffer side wall than the standard BT-023's according to my local bike shop. They were a huge improvement over what was on there.
Change the coolant. Do the coolant tank mod. Sell the old tyre's to Hamish! He'd love 'em....
Cheers.
Nick.
Dunlop Q2's on mine with 180 at the rear. With the 180 you will have to be perfect on your alignment or the chain will rub the edge. Very sure footed even in the rain but don't get a lot of miles out of them which is fine with me
- ducinthebay
Thanks all,
I searched around the site to find the CBR600 filler mod, and I think I get the gist of it. The link to the pictures in the stickys section doesn't work, but I found another pic after some work. Any other pictures of the radiator cap mod would be appreciated. I bought one on e-bay with hoses for $20. Looks like a great fix for a questionable design.
I'm putting on a 170 Michelin Pilot on the back, and a friend is giving me a slightly used 120/70 for the front to get it on the road, and get an old wheel out of his garage.
Any other recommendations for radiator fluid beside Water Wetter or Evans? I need to do my ST2 also, so I guess I'll get a bit more while I'm ordering.
- year: 1989
Here is a pic of the CBR600 rad cap mod I did on my 906. I assume they are the same or at least similar.
Since that pic was taken I have removed the expansion tank as it's not req'd when running Evans.
Hope this helps.
Hope this helps.
Lane
- ducinthebay
Beauty, thanks,
I'll do the same next week.
Phil
Phil
- Derek
- year: 1994
Rather than the Honda CBR filler mod I've been considering fitting the radiator from an ST2/3/4. I've measured one up and reckon it will fit but due to the curved shape the fairing sides would need to be trimmed to clear it, but this would be behind the air conveyors and hidden from view. The ST radiator has both top and bottom hose connections on the left hand side but a bit of plumbing work with hoses should sort that out.
- persempre907
If you fit the 180 rear tires you'll have an harder bike to ride, above all in the corners.ducinthebay wrote:Now, I'm going to remove those 14 year old tires that look almost new. Anyone have recommendations on what to put on there? I've been a bit of Pirelli fan on the ST4s and the Sport. Should I go with the 170 or is there an advantage to go with a 180 rear?
Phil
I would go with 170 and... I'd replace the coolant.
- ducinthebay
Got a brand new 170 tire on a black rim to go on. I'll change out the white one later.
Drained the coolant. It was a very nice crystal green, and everything inside looks nice and shiny. I'll flush it with vinegar and water tomorrow, and I'll be refilling with Engine Ice by recommendation from a KTM mechanic. On sale at Cycle Gear for $18 for 1/2gallon.
I'm also doing the Aprilia thermostat mod, ($40 on ebay, with hoses) and the CBR600 radiator cap mod ($20 on ebay) I'll take a few photos when I get it together.
Life has gotten in the way of getting on the road, and I'm skipping out of chores right now, and need to get back to them.
Cheers, Phi
Cheers, Phi
- ducinthebay
Update:
I got a few days to work on the 907.
Putting on a set of Michelin Pilot Powers, one I had, one I got from a friend. 170 in back, 120/70 in front.
Pulled the front wheel off and decided to flush the forks. Good idea. ATF in the left leg, and fork oil in the right leg. I'll refill them in the morning. Several of the triple clamp bolts were loose, as were the fork caps, and the drain screws were finger tight. Forks slide up and down nicely after a bit of working them, and no pits in the chrome.
I'll put some grease in the steering stem bearings while I am this far, but they feel good so far.
All looks good, just needs a going over after 23 years. Replacing rusty bolts here and there, but not many parts.
Next is the Relay mod.
Eastern Beaver has some very nice kits ready made as well as an updated fuse box which is a mod I am currently working on.
He aslo has ready made kits to upgrade the voltage regulator to the Shindengren Mosfet SH775 which is a true regulator not the usual shunt type
roadstercycles also has nice kits as well
of course you can always make your own
http://roadstercycle.com/
http://www.easternbeaver.com/
