Paso wants to start
- year: 1993
Paso wants to start
As some might recall brought home a $650 88 parts bike last month. Upon closer inspection it appears to be very restorable so today I cleaned all around the bottom of the eng since it didn't even have a oil filter or drain plug in it. I replaced all that stuff and cleaned the plastic filter in the side. It took a little while cranking in several second spurts mindful of the starter and no fuel going through the fuel pump. I mainly just wanted to see the oil pressure light go out which it did. On a whim I sprayed a little carb cleaner across the top of the weber and it tried to start. Quite a noise with no exhaust on it! My wife came down and ask if was shooting at something! Might try and do something custom with this, nice to know that at least it's been saved from the parts bin. Regards Arch.
- englishstiv
Re: paso wants to start
"nice to know that at least it's been saved from the parts bin."
That's the really nice part of this thread and would be great to see some updates on the rebuild, what parts are missing? good luck
DUCATI 907ie 1992
- year: 1993
Re: Paso wants to start
Well it's pretty much all there with the normal cracked and chipped fairing pieces and even came with a couple extra side fairings in same condition. It also has the euro taillight and bub mufflers along with the clutch cover which would make it about worth what I paid for it. The tank is trashed but seems to be a plentiful supply around so I'll stick it in the lineup for eventual attention. Thanks Arch.
This is a good thing you are doing. Please provide a laundry list and I will see what I have duplicate spares of.
- fasterdammit
I have a spare tank & petcock I'm willing to part with; presently red, no cap. It wasn't pristine, as I recall, but I haven't looked at it in a while. If you're interested I can come up with a real description and pictures. Just let me know.
1988 Paso 750 #753965
1997 Monster 750
1997 Monster 750
