New Design Timing Belts. What do you Think?
du907
Post by du907 »
I just got these new belts from Bevel Heaven made by an Italian company named Bucci. They are Kevlar and are for various Ducatis, including the 907ie.
https://store.bevelheaven.com/engine-re ... down-menu/
When I got them, they have wedge shaped teeth. Our bikes usually have rounded teeth, 70 teeth per belt. I talked to the guys at Bevel Heaven and he said that Bucci has a patented design with these teeth that make them work on Ducatis that use the round tooth belts or the wedge shaped teeth, these belts have 70 teeth. I have enclosed a picture, take a look and see what you think.
The old or original belt is on the outside, the new design belt is on the inside of the bend.
See those 2 points at the end of the teeth. There is some other "textures" on the teeth that doesn't show but apparently this is their patented technology.
Re: New Design Timing Belts. What do you Think?
Bucci belts are some of the best and always have been
persempre907
Post by persempre907 »
higgy wrote:Bucci belts are some of the best and always have been
Yes, it's so. Bucci is a very well named brand, but... talking about belts... I always prefer to buy them at the Ducati store.
900streetfighter
Post by 900streetfighter »
They are not much cheaper than oe(price is each belt?). Do they still need changing every 2 years?
st2sam
Post by st2sam »
Nice.
IMO the Kevlar is just as, if not more important, than the shape of the teeth.
Thanks for the heads-up! :thumbup:
900streetfighter
Those BH belts have similar tooth to Dayco belts, with a 'groove' at the tip of the tooth.
