90 900 Supersport Tidy-up
The Paua Poacher
Re: 90 900 Supersport Tidy-up
Post by The Paua Poacher »
With JE 11.5:1 high comps going in can anyone give me an idea to what I should retard the timing to start with (running 96 at worst)
Standard Marelli ignition (1989 to 1990) ... Very minor port (as had been messed with had it tidied up) .... Weber 116 .... Standard but new valves, guides
11.5:1 is what the pistons say or what was measured after installing them?
2° is what you`d usually start with.
If the heads are off I`d take the chance to verify the correctness of the TDC marks. With the production tolerances they can be 1-2° off.
The Paua Poacher
Good point and thanks
Andrew2
Post by Andrew2 »
ducinthebay wrote: as the 900SS was a very rare beast indeed.
Phil
How rare are we talking Phil as there's one for sale locally for $5000 with 40,xxxkms on it.
Andrew
1.931 (1989: 1.471, 1990: 460)
Andrew2
Post by Andrew2 »
paso750 wrote:1.931 (1989: 1.471, 1990: 460)
Thanks G.
The Paua Poacher
Forks with New Stanchions, Seals & Oil.jpg (38.7 KiB) Viewed 16664 times
Next up the Forks
Sliders blasted & painted
Stanchions were straight but just started to bubble ... soooo in with some new ones to go with Bushes, seals, etc
Easy enough job
Old Stanchion & bits in the bag.jpg (34.32 KiB) Viewed 16664 times
The Paua Poacher
The Triple
Same pretty simple ... new bearings in after packing
Press Fitted Bottom Triple.jpg (29.93 KiB) Viewed 16664 times
Installing Spacer.jpg (23.1 KiB) Viewed 16664 times
Triple Installed.jpg (43.95 KiB) Viewed 16664 times
The Paua Poacher
Fairing Frame blasted & painted
Clear out the thread
Starting to put some of the work already done on to the frame ... starts to look like a machine
The Thread.jpg (27.36 KiB) Viewed 16664 times
Frame Installed.jpg (44.25 KiB) Viewed 16664 times
The Paua Poacher
The Dash & the Headlight
She was smashed ... previous owner had run into the back of a truck with an overhanging load
What you see is what was under the black tape holding the gauges together & a replacement Headlight
Couldnt save any of that so in to search mode for replacement
On the Headlight I mixed & matched a replacement headlight with what I had
Some of the reflector has sh!t itself on the new HL which really p!sses me off as that wrecker has consistently sold wrecked bits at top dollar but consistently sent up crap - bought a rear light that was broken in the exact same spot as the one I needed to replace... the clip ons were good for nothing when I got ... & the airbox I bought is missing clips/bungs & the seat that sits in the carbs is deformed (I will take that up with them soon to be fair)
In with new bulb & T10 LED ... the right grease & back together
On the Dash sourced parts & in to the fairing frame
After reading various on LED's I am going to pop some T5's in the Dash Lights (have sourced coloured LEDs from China for about a coffee in cost)
In with new bulb & T10 for parking light.jpg (25.14 KiB) Viewed 16641 times
Completed Headlight.jpg (26.27 KiB) Viewed 16641 times
Last edited by The Paua Poacher on Thu Jun 11, 2015 5:56 am, edited 1 time in total.
The Paua Poacher
Dash Photos
mmmmmmmmmmm VEGLIA (hope I spelkled that right)
When installing I replaced all the rubber, bolts, etc, etc at same time (thats not the expensive bits)
Internal Electrical Dash Panel.jpg (33.45 KiB) Viewed 16641 times
Sick looking Back of Dash.jpg (30.84 KiB) Viewed 16641 times
Instruments on.jpg (40.01 KiB) Viewed 16641 times
The Paua Poacher
Tank
While I wait for the Primary Drive to come back so the cases can come back together I started thinking about her clothes
As mentioned this has been down the road ... old owner hit overhanging truck load so the fairing frame took the brunt of the ding (damages were all consistent with that)
The front fairing on the machine I had was fibreglass so found a replacement ... still needs a major sand, glue & ground up paint
I haven't taken photo's of the fine stress cracks (there were only a couple) ... or the half ars$d repairs behind the fairings (all done before) but have shown the tank has been caught in time with only a bit of rust in one corner & not terminal (great)
I wont do this work as the tank needs a paint strip... repair weld the rear mount ...a little panelbeating ... reseal & full paint ... but is underway while I work on other bits
Question ... anyone have a fuel sender (would consider a pump as well) they are happy to move on? ... please PM
Need a Seat Cowl as well?
The Fairings.JPG (58.56 KiB) Viewed 16607 times
Tank Rust just started.JPG (30.02 KiB) Viewed 16607 times
Bottom of Tank.JPG (48.27 KiB) Viewed 16607 times
ducinthebay
Post by ducinthebay »
Fuel pump bits are all the same as the SS series from 1991 to about 2001 when they went to Fuel Injection.
Nice work so far.
The Paua Poacher
Phil
Thanks for the encouragement ... made a couple of errors in coatings (should have powder coated triple, sliders & clip-ons but that is an easy fix)
I thought that sensor would be different as the tank is a different shape & the Reserve is shitty as it is
Righto will start the hunt now as makes bloody easy
ducinthebay
Phil
Andrew
A bit late on my reply. The 900ss was sold in only a few selected countries. USA was not one of them. The SuperSport series came to the U.S. in 1991. Very similar machine of course.
