You've got me there. It has not been drag raced and I would not expect it to reach that speed within 1/4 mile. It is very fast and will have the speedo 'off the clock' at 9000rpm. The top speed figure has been calculated due to wheel size, gear ratio's, rpm etc. Oh and the ride has a bit of a vomit factor.steele wrote:Proof if you please young sirJWilliam wrote:My Paso will do 167mph, it is modded but normally aspirated.
Not knocking you mate its just that in reality speedo readings and calculated speeds never seem to be the same as when timed over a given distance at an event mine runs between 115 and 120 at the end of the 1/4 thats with the gas on and remember i am rather LARGE as well someone smaller could do Much betterJWilliam wrote:You've got me there. It has not been drag raced and I would not expect it to reach that speed within 1/4 mile. It is very fast and will have the speedo 'off the clock' at 9000rpm. The top speed figure has been calculated due to wheel size, gear ratio's, rpm etc. Oh and the ride has a bit of a vomit factor.steele wrote:Proof if you please young sirJWilliam wrote:My Paso will do 167mph, it is modded but normally aspirated.
