It is currently Sun Jun 24, 2018 3:33 am
 Post subject: looking for rear brake disc from KEITO or AWACK
PostPosted: Tue Dec 06, 2016 5:38 pm
the disc is slotted. You can still get the front discs but I can`t find a matching rear.
I`d be thankful for any lead.
It`s basically impossible to find any info about both brands.
 Post subject: Re: looking for rear brake disc from KEITO or AWACK
PostPosted: Wed Dec 07, 2016 11:23 am
Gerhard, if you are really desperate, try these guys: http://www.isrbrakes.se/products/brakediscs/custom/
Not cheap but I contacted them once for a new (unobtainable) rear disk for my old Bimota SB4.
had the same reason: couldn't find the wanted pattern (in my case the otiginal pattern).
They do all kind of tailor made brake discs etc.
Oh, quality wise they are top notch.
PostPosted: Wed Dec 07, 2016 2:04 pm
Hello,
If you scan your stock disc, you can then forward it to a machinist with a water jet or plasma mill and have one made. Some of my friends here that are into 3d printing have scan apps on their cell phones.
Hope that helps.
PostPosted: Thu Dec 08, 2016 8:33 am
I don`t have one to scan as I only have the original brake disc. Finding replacement rear discs is not a problem but finding exactly that one is. The next thing is that if I had a copy made it wouldn`t have any homologation numbers on it. Noone may notice but if someone did I`d have to replace it and the money spent would`ve been for nothing.
PostPosted: Thu Dec 08, 2016 3:33 pm
Any machinist that can produce the disc can put any id numbers you want in it.
