M1R Fork rebuilds
M1R Fork rebuilds
Can anyone recommend a specialist to strip, hard chrome and rebuild my 907 forks in the UK? I got the bike recently which had been in storage with heavily rusted stanchions. I tried riding it but both fork seals were destroyed within a couple of miles, unsurprisingly.
Many thanks.
Many thanks.
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1985 LAVERDA SFC 1000
1993 DUCATI 907IE sold May 2017
1993 DUCATI 907IE sold September 2017
1995 TRIUMPH DAYTONA SUPER III
1980 LAVERDA JOTA
1982 HESKETH V1000
Re: M1R Fork rebuilds
While I have no experience with any suspension shop specially not in the UK, there`s for example http://www.pittedforks.co.uk
Thanks for this. Alternatively, new stanchions are available for the 906 but I don't know if they are the same as the 907 stanchions ?paso750 wrote:While I have no experience with any suspension shop specially not in the UK, there`s for example http://www.pittedforks.co.uk
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
- englishstiv
These guys are the go to blokes for Paso forks they can also adapt and alter the internals for you, they were back in the day quite reasonably priced too although I used them for something non Paso related.
http://www.maxtonsuspension.co.uk/
DUCATI 907ie 1992
I would always prefer re-chroming over a set of (mostly non originals) new stanchion tubes.
Quality and dimension wise it's a better choise and also price wise (count on approximately £160-£200 incl. aligning for a set of tubes).
There are a lot of replica's but regularly they have deviant length, inner dimensions, lack of wholes etc.
Have done it a few times ..... 9 out of 10 times it's better than new (although the original Marzocchi M1R chrome is also very good).
Good luck!
Good luck!
the answer would be no but they may still work assuming the inner dimensions of the fork legs are the same which they probably are. The internal parts of the 906 & 907ie forks have identical part numbers.Alternatively, new stanchions are available for the 906 but I don't know if they are the same as the 907 stanchions ?
I couldn`t find any info about the length of the right stanchion tubes but the left one of the 907ie is 640mm, the one of the 906 is 630mm (and the one of the P750 is 580mm). So if you lower the fork in the triple trees a little it should work. Of course being a centimetre shorter you`d also need shorter fork springs.
- ducinthebay
Nice to see someone is doing this. I searched a few years back, and could find nobody in the States that would do it. Ended up finding new legs, which weren't cheap.paso750 wrote:While I have no experience with any suspension shop specially not in the UK, there`s for example http://www.pittedforks.co.uk
Let us know what he quotes you for a set of legs. I might pay the post from California to have them done.
The company I am using is called DYNASURF in the U.K. They arrange collection and return. Price to check straightness, straighten if necessary, grind and hard chrome is GBP135 for the pair plus VAT. They are a large company who specialise in industrial / heavy plant hydraulic cylinders, oil & gas, aerospace etc. Motorcycle fork stanchions are a sideline. Surface hardness is important but so is surface finish. Too highly polished means the seals will run dry and be destroyed very quickly. Too rough is good for oil retention and lubricating the seals but won't please the MOT tester....ducinthebay wrote:Nice to see someone is doing this. I searched a few years back, and could find nobody in the States that would do it. Ended up finding new legs, which weren't cheap.paso750 wrote:While I have no experience with any suspension shop specially not in the UK, there`s for example http://www.pittedforks.co.uk
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
It's Ohio but they do rechroming motorcycle stanchions, $240 a pair....
http://www.unitedsurfacefinishing.com/home
- year: 1989
HI RB. Have you had the forks back yet? If so, how would you rate the work that was done? I have two sets I need re-chroming. Cheers
Paso 750 Yellow in bits
Paso 750 Red x 2 (one running)
Paso 906 in bits.
It is a habit I cant seem to give up!
Paso 906 in bits.
Forks not back yet but should be by the middle of the week. I will let you know and post photos, if I can figure out how too... Not had much luck with photbucket....
Bought the new fork seals from the BMW people "Motor Works" - £27.70 for the set with postage.
Got the new timing belts and will try the guitar tuning app on my Windows phone for tensioning. Apparently I need 100 to 110 Hz which is Piano key No.24, or halftone between A2 and G2 :-)
RB
1980 LAVERDA JOTA
1982 HESKETH V1000
1980 LAVERDA JOTA
1982 HESKETH V1000
