It is currently Mon Sep 16, 2019 4:26 pm
 Post subject: 320 mm disc conversion with 65 mm calipers
PostPosted: Fri Feb 23, 2018 4:37 pm
I am doing a 17 inch conversion with custom spoke wheels, and at the same time upgrading the front discs to 320mm. I have a set of newer 65 mm bolt pattern brembo calipers, and therefore need a bracket. All I can find is brackets made for 280 mm discs, so the question is, does any of you have experience with this conversion? Drawings of a bracket, or know of any finished products?
Best regards
Michael
 Post subject: Re: 320 mm disc conversion with 65 mm calipers
PostPosted: Fri Feb 23, 2018 5:16 pm
from the P750 FAQs: https://www.box.com/shared/lzd6kxnkgk
PostPosted: Fri Feb 23, 2018 8:48 pm
Awesome. Thanks. Did not think to look in the paso section.
