Where can I buy new clutch oil drain bolt?
I can’t find it on ebey, and I don’t have a Ducati dealership.
Sagi
New clutch drain bolt
Re: New clutch drain bolt
Do you mean the air bleed bolt on the clutch slave?
it's the same as used on the brake calipers if that helps
- Derek
- year: 1994
M10 X 1mm banjo bolt. Google it, they are readily available.
I’m talking about that one:
I couldn’t find on ebey...
Hi Sagil,
I bought mine at Stein Dinse in Germany: http://www.stein-dinse.biz
They ship worldwide.
Part number 63140161A, Duc bleeder screw 08/P4 30/34 M10x1, 15mm, silver
https://www.stein-dinse.biz/Brembo/Supp ... 11167.html
Good luck.
Best regards, Ronald
Good luck.
Thanks!
I will purchase it from your links
I guess its all in knowing the lingo Sagil , round these here parts we call, that a" bleed nipple" and I can imagine there are reasons why it aint called that in all parts of the world , but anyhow search that on ebey
and you will be spoilt for choice
