I just bought a 907ie project for myself.
I was thinking of updating here how the project is going.
Here's a picture of the condition of the bike for this moment.
I don’t like streetfighter lookNito wrote:907 streetfighter looks very cool
HIccmman wrote:Hi Vainika
looking forward to hearing your progress. Post lots of pictures, and plenty of detail about what you are doing.
So the engine is out, are you doing a complete strip and re-build?
Any problems with electrics?
My fuel pump in the tank was shot, they are available cheaply from other sources. I found mine on Gumtree (local version of ebay), for £25. It was a brand new spare for a Mazda MX5, which owner had sold.
Good luck and have fun!
The images are fixedDerek wrote:Pics are not showing!
Thank youenglishstiv wrote:On the 907ie the ECU sits on 3 small rubber bushes beneath the rear part of the seat just in front of the rear seat inner nacelle.
If you look at the frame you should see two lugs on the inner frame carrier and one in the middle directly opposite on the other frame carrier. the electric cable connects to the right side of your bike ( sitting on it )
Best thing is download the online manual in the 907ie Tech FAQ.
Looking at your Fame photo's I would be interested to confirm your frame number as it may be a 906 frame if you can't locate those lugs? Again check on the Tech FAQ for all the Paso model and 907ie numbers. Does your tank have an internal fuel pump fitted?
