It is currently Thu Dec 03, 2020 2:05 pm
 Post subject: Pase Engine Number - How old is this engine?
PostPosted: Sat May 16, 2020 8:36 pm
Hi Folks. I just bough a tatty old Paso 750 1990, so one of the last. Log book says engine number is 754496, but the previous keeper said the engine had been replaced. Having had a look, it is stamped ZDM750LE750659. I guess that it is slightly older than the original engine? Does the LE mean anything? Many thanks.
Paso 750 Yellow in bits
Paso 750 Red x 2 (one running)
Paso 906 in bits.
It is a habit I cant seem to give up!
 Post subject: Re: Pase Engine Number - How old is this engine?
PostPosted: Tue May 19, 2020 6:02 pm
I just checked the engine I have on my Special, it was from an Elefant 750 and the number is ZDM750LE*751354 , not far from yours.
my engine was coming form a very early bike, I wonder ... they look the same , the valve train is the same and should be a straight swap.
The primary on the elefant da 31-62, wilst on the Paso it is the same as the SS 36/71; The gearing is different too, unfortunately the only way to check that is either opening it or with a goniometer and a lot of patience
Users browsing this forum: Google [Bot] and 10 guests
