I have pulled the ignition switch off and found that the locking pin has snapped the housing
Is there any other model ignition switch that will fit this bike
750 paso ignition switch
- randtcastell
Re: 750 paso ignition switch
I am no specialist, but I assume you mean what I think you mean. If so then I do believe 750's and 900's '88-91 and may other models into the '90's all the same part number. Others will confirm or correct this.
https://www.ebay.com/itm/Ducati-900ss-7 ... xyfyhRYYT0
You may find a nice used item fairly quickly. $40US seems like a fair price. Good Luck! :^)
1987 Ducati P750
1973 Honda CB450
2022 KTM RC390
1973 Honda CB450
2022 KTM RC390
Thanks for the reply, no I’m after the ignition key switch barrel
- Derek
- year: 1994
750, 906, 907 and 750/900 Supersport all have different part nos. but only the last 3 characters change so probably differing connectors/cable lengths. I be surprised if one from any of these models didn't physically fit but might need the wires adjusted.
Also the height of the barrel is different ....
Thanks for your help with this fellas, I will try to find one to fit this model
