Weber DCNF fuel pressure issues
Fulvia-hf
Re: Weber DCNF fuel pressure issues
Post by Fulvia-hf »
Hi Higgy,
I think your answer is not one for this thread. Charging problems I do not have. I have replaced the battery and al the 30+ year old thick wires for brand new extra thick wires. A new V/R finishes the job.
william
JWilliam
Post by JWilliam »
Fulvia-hf wrote: Sun Sep 19, 2021 5:27 pm A problem to have fixed later is a slight wobble in the front rim. Very annoying around 50Kph and again somewhere between 100 and 140kph.
Cheers, william
I expect this is due to the steering head angle. If the head angle is too steep the bars will shake. Try and reduce the spring pre-load on the rear shock absorber ie drop the back end a little.
