Checking electric system
Finnpaso
year: 0
Re: Checking electric system
Post by Finnpaso »
Yes! When You look closer, that plate, where 907 RR is fitted, is insulated from frame with 3 rubber holders and that RR cover(fins) are not connected DIRECT to earth ! Surely RR is conncted to earth with that minus(-) wire, but what happens, if that fails, or some bad connection in that wire???? I can quess.... :,( I have read long time ago, that someone missed his RR , when that - wire went broken and immediatelly i made that extra wire from fins to good earth. Anyway that is "safety thing"... :thumbup: :smoke:
907IE -91 red/metal grey
907IE -91 red
Janky59
Post by Janky59 »
For my winter project I’m going over my 907ie to learn it’s history, freshen up what I come across, clean all over, and learn how it’s put together.
One “Easter Egg” I came across was this nest of hotness. I peeled away all the crummy insulation, pulled connectors apart, scuffed and cleaned and heat shrink-ed things back together.
Then I learned someone had cut the red wire from the leads coming from the stator/engine.
From my reading of past topics this tells me the reg-rec has been replaced. I looked it over but can’t really tell the brand.
In the 500 or so miles I put on it since I took delivery the charging system seems to be working ok, but I hope to head off future troubles by this maintenance and cleaning all the grounds.
Current moto stable:
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
You can post a picture of the reg/rect. Maybe someone can identify it.
I'm wondering about the cable with the cut red wire. Is that an original one? All the wiring is in hoses while that is a 3-wire cable. :huh:
Janky59
Post by Janky59 »
I took a couple of pictures, getting the best view I could without removing the reg-rec. It looks to me the original Ducati mounting holes line up with the reg-rec bolts.
Paso750, I don’t know if the 3 wire cable is the original or not. I think I am the 3rd or 4th owner so I don’t know the bikes long term history. There are no numbers or wording along the outer sheath for what that is worth.
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
Hard to say what model reg/rect it is. I searched through pictures but didn't see one with that order of wires (two green in the middle and the yellow on the outside)
Post by Tamburinifan »
Looks like a modern Ducati one, not original.
Loosen it and see what it says, like Shindengen, letters, numbers.
Good idea regarding Shindengen, Gert.
It looks like this one: https://www.stein-dinse.biz/product_inf ... rettyPhoto
Tamburinifan wrote: Sun Mar 16, 2008 6:38 pm Any more vital wiring/connections to check?
Aw come on Gert :D , you know these bikes . It your looking for things to fix just ride it round for 5 mins :lol: .
I think the extra earth wire is a good idea ....so much so that I am going to do it to my quad as Im having alt issues with it .
Janky59
Post by Janky59 »
Hi Gents, I took a few minutes to check out the reg/rec. on my bike.
Here a picture of what is stamped along the bottom:
SH673-12 is the marked there.
A couple of the results from my web search were eBay listings of this reg/rec from France for the DS engined Ducatis, the early 2000’s models.
For general knowledge I’ve included a picture of the Lancia Fiat relay that is there. I don’t know if this was the OEM part or a replacement installed sometime in its history, but maybe this will be useful info for someone.
I appreciate any comments or info, regards.
‘21 Beta 390RS
‘18 BMW R1200RT
‘92 Ducati 907ie
