Ducati Paso 750 complete restoration
ludiluka
year: 1985
Post by ludiluka »
Hello,
New Paso owner here but not newbie ducati owner 🤣.
I just started full restoration on my bike and i already have some questions.
I dissasembled the bike. Frame is off to sand blasting. And now i started working on suspension. I dissasembled front fork and i think that i’m missing part circled on the photo. I’s missing in the leg with rebound adjustmend. Am i correct? If so does anybody have this part for sale or at least fork dissasembled so that can take some measurements.
murphus
Re: Ducati Paso 750 complete restoration
Post by murphus »
The Marzocchi M1R manual shows a "ferrule" for each spring, suggesting someone's been in there before ...
1973 BMW R75/5
1976 Suzuki GT185
1983 Lavarda RGS 1000
1988 Ducati Paso 750
1995 BMW K75
ludiluka
year: 1985
Post by ludiluka »
I checked manual. Problem is that it's different than in other leg. That's whay i'm searching for one or at least some measurements that i can make one
The parts catalogs are not 100% reliable. It's possible that early M1R forks had that "ferrule" in both legs and later didn't. If you look at the 906 parts catalog (which was probably printed some time after the one of the P750), it shows that part only in the left fork leg. If that Öhlins is originally from your Paso it's an early one in which case by my own theory the fork should have those pieces on both sides.
But as Murphus said someone else may have rebuilt the forks in the past and forgot to put it back in. Or the factory did or it's not the original fork anymore.
What's the stanchion tube length?
ludiluka
year: 1985
Post by ludiluka »
Looks like there is no spacer in one leg. I managed to get another forks and also therre was no spacer.
New day new problem. When i took clutch apart i didn't noticed marking (dot) on clutch drum. I checked manual andiit doesnt mention marking on drum anywhere and pressure plate has marking 1 2 180* degrees apart. any specific way to align it?
ludiluka
year: 1985
Post by ludiluka »
Is there any good supplyer of stickers/decals for fairings? I need all the stickers on the fairings. As close to original as possible.
ludiluka
year: 1985
Post by ludiluka »
Promished photo.
I rebuild everything except engine. (it has a bit more than 20k on the clocks i removed side covers and everything looks really good inside i also checked cylinders and they look brand new inside i did adjusted the valves new belts, and pulley bearings.)
Currently waiting for wheels send them for fresh diamond cut. Now i have to start working on fairings. Still searching for recomendation where to get stickers. also does anybody know where theese two bolts came from? can't remember from where i removed them.
Those two bolts don't look like anything from a Paso. Did you remove the two bolts from the lower triple clamp, maybe. The ones that adjust how far the fork can be turned to left or right?
ludiluka
year: 1985
Post by ludiluka »
paso750 wrote: Mon Dec 18, 2023 9:01 am Those two bolts don't look like anything from a Paso. Did you remove the two bolts from the lower triple clamp, maybe. The ones that adjust how far the fork can be turned to left or right?
I also tought that i removed them from steering stops. But there is no adjustable steering stops on paso.
I removed them from paso because i was doing dissasembly in my new workshop that was compleatly empty even without workshop equipement should take more photos next time
Post by Tamburinifan »
Two bolts from front tank rest? Don't remember what they look like.
On mine there are. I always thought those were original but maybe one of the past owners drilled the holes and fitted adjustment bolts.
Could it be the bolts to mount the brake line splitter in front of the lower triple clamp?
Well I was going to agree with G about being non paso , but I got a feeling I have seen them before ......and I have a Paso in bits so .... coincidence ?
Maybe from around headlight mounting subframe area , buffers ?
ludiluka
year: 1985
Post by ludiluka »
Me again.
Rebuild is slowly coming to the and in i can not figure it out how to install front fairing to the bike i tried from the front from the top,… just can,t figure it out and i do t want to strech it so that i don’t crack the fairing. Is there any video available of installing/removing front fairing
enginerd
Post by enginerd »
Quick question, did you replace the oil lines on the coolers or were they replaced prior? I've got new hoses for mine but looking for tips to replace over the barbed fittings with the couplers on it(without destroying them). Thanks!
ludiluka
year: 1985
Post by ludiluka »
Almost there
