Updating the voltage regulator
Re: Updating the voltage regulator,almost done
Not quite finished yet but is now charging properly with dual headlights on.
Still need to route a few more wires through the new fusebox to get them off the battery and decide where I want to put the regulator permanently but it works :thumbup:
Took the lithium out in favor of a glassmat while I am experimenting, lithium is kind of particular on charge rates
demidesmo
Post by demidesmo »
Very interested replicating what the original poster has done as I've a Mosfet Rec knocking around a box of bits in the garage. I've been running HIDs for a couple of years and they are great in terms of being able to see things coming towards you. I may be asking questions in the not too distant future about the installation.
steved001
Post by steved001 »
Was the connector issue one of the bullet terminals up by the steering forks? I'm struggling with an underperforming charging system, no charge at idle, about 13 V at 2500. All bullet connectors for the reg. seem to be OK.
