Ducati Paso 750 complete restoration
enginerd
Re: Ducati Paso 750 complete restoration
Post by enginerd »
That's looking beautiful! :mrgreen: :thumbup:
ludiluka
year: 1985
Post by ludiluka »
One more thing.
Can somebody identify when the bike was produced according to the frame number
ZDM 750 P 0370 88 130
ludiluka
year: 1985
Post by ludiluka »
Is this correct float for paso carburator? In manuals i only find round float.
Mmmm I could only find round ones too . That float looks a bit special with the dimples .... possibly to clear jets in the bowl.
Some smarty pants :P round here might have the know .
https://www.ebay.com/itm/166536207590
then I found this
ludiluka
year: 1985
Post by ludiluka »
ludiluka wrote: Thu Feb 06, 2025 7:37 am One more thing.
Anyone with knowledge i need to know production year for registration.
1988 ?
ludiluka
year: 1985
Post by ludiluka »
Sorry for my stupidity i was reading numbers from plate on the side of the frame on frame neck it's stamped ZDM 750P * 751066
enginerd
Post by enginerd »
Yup, float looks the same from one of the two webers I have.
ludiluka
year: 1985
Post by ludiluka »
Picture of the finishec bike. Took it for the test ride and first 150km everything was great and than i started losing one cylinder. First outing of one cylinder was short but it became longer and longer. This was happening across all rpm range. When second cylinder came back to life it was running ok. So i think it is not ful but rather electrical problem. where to start? what is most common problem.
sounds like a bad ground or maybe the ignition switch.funky pickup..... gonna have to do the work to figure it out. Lots of fixes round here :phone: :choo: :truck:
murphus
Post by murphus »
Check voltage at the ignition coils. My Paso was only showing around 10-10.5 volts at the coils. I wired in a relay for full power from the battery. Check the Technical FAQs page for a schematic.
1973 BMW R75/5
1976 Suzuki GT185
1983 Lavarda RGS 1000
1988 Ducati Paso 750
1995 BMW K75
Witzie
Post by Witzie »
I had similar problems with my 906 which has the same weber carb. Right after I replaced a lot of part of the weber using a rebuild kit it ran really well for a couple of 100 kms. Then I started to loose one cylinder so , like you, I was convinced it was a electrical issue. After replacing a lot of parts it turned out that some dust from the new gaskets that I had replaced clogged the carb. After a good clean of the carb it then started running fine again.
Kawasaki Z700 1987, Kawasaki ZL1000 1990, Ducati PASO 750 1990, Ducati 900ss 1994,
Kawasaki ZZR1100 1993, Ducati Paso 906 1989
Dust from the new gaskets ? :?: :shock: :lol:
ludiluka
year: 1985
Post by ludiluka »
So I left Paso sitting for few day and here we go again. Carburetor float didn't closed the fuel and i have engine full of fuel.
I drained the oil. And maybe it's not electric. What is correct float height because I'm finding two different values on the internet. Also interesting thing is that float was closing fuel correctly before for at least a month.
level with the top of the card as you hold it upside down. It is possible for these floats to get saturated with fuel as they get older keeping them from closing.
