Weber Carb settings
Fireypete
Weber Carb settings
Hello all
I've found a a couple of articles, one referred to a swap to a 40 DCNF, I'd rather keep it stock. The other lists:
150 Mains
F27 Emulsion Tubes
60 Idle Jets
4.5 Auxiliary Venturies
Float at 43mm
All double Dutch to me, but the Weber shop will.understand and have the parts. I can have those parts put in as part of the overhaul. Also, thoughts on the float? Should I just replace it?
Pete
150 Mains
F27 Emulsion Tubes
60 Idle Jets
Float at 43mm
Pete
Kiwi Rider
Re: Weber Carb settings
Hey Pete, I had a weber specialist overhaul my carb but it's still fluffy and hesitant getting back on the gas coming out of a corner. They suggested increasing the size of the pump jet but it turned out the previous owner had already done that tricks so I actually decreased it to a .35 (I think .25 is stock), but it didnt help. I'm assuming they set my float height to the stock setting, but I have not checked it. I will get back to this issue latter on when I get the bike mobile again. I want to stick with the stock carb too esp as I spent $700 getting it reconditioned!
700 bucks ! far canal ! did he gold plate it ?
As fa as I know nobody has got that weber to behave properly on the Paso . There are threads and discussions here where peeps have tried .
Dont get me wrong , Im not trying to piss on your campfire . Im sure there is the right set up , just seems elusive . Mostly they are pretty good but the hesitation just getting off neutral throttle seems to be a hard thing to cure . Bit like meeting the most awesome chick in the world .....only to find out she farts in bed , you have to figure out if you can live with it .
Before you get to involved in tuning the weber I would check cam timing as this was a bit hit and miss from the factory and its not unheard of for there to be 8deg difference between cylinders . I dunno just how much difference this will have on tuning if your going to assume both pots are the same ( and they might be ). I have been looking at the Chinese type FCR's , some good reviews , and I bought a whole carb for my Suzuki LTF off the same guy and apart from both the throttle and choke cables needing a bit of minor adaptation it bolted straight on , started and ran just fine .
Fireypete
Hi guys, I will have a chat to Weber Performance, not far from me. A fella who works on these for a living may have some suggestions. I have found and written down a couple of set ups and will see what he thinks of those as well.
When I get the bike running I won't use it much as I want Brad to do a service. I will get the valve clearances done and definitely ask to check timing. The belts look new but I'll put new ones on to be safe. I'm booked in for Nov. 24th. Brad reckons things are going a bit slow as he is only booked out 3 months in advance...its usually 5!
Im pretty sure it was Brad that I got my adjustable cam pulleys from .
Kiwi Rider
No but he did bead blast it!
Theres was heaps wrong with it, a lot of bits replaced and time spent on it. It came back looking like new.
Hey what site were you looking at the Chinese FCR's on? Is there room between the cylinders for two carbs? I know the F1 has the rear cylinder carb on the opposite (rear) side.
Ali express and Temu .
Bead blasting ? , did they come up OK , just that I have bought a pair of Delorto PHF36's for my Guzzi and they do need some attention cosmetic wise but I didnt want to polish them . I thought maybe soda blasting .
Fireypete
Regarding carb float. Thornbury Carbs recommend the poly plastic float for Ducati's. That's what the bike came with. Deswoodau found the same.
Weber Performance didn't know about plastic, as they usually come with brass, so I'd be guided by Thornbury. My carb has been tinkered with I think
It has main jet 145
Idle of 50
Emulsion f27
When I get it all back together I'll let you know what it has
It has main jet 145
Idle of 50
Emulsion f27
Kiwi Rider
Possibly soda blasting, couldnt be sure, but looks good
That does look good
Fireypete
Float Height thoughts.. Brad the bike boy said 44mm float height, I have seen 43 on a forum. Mine was and is 42mm. Does a couple of mm make a diff?
Well yeah , it must make a difference .....but wether it makes enough difference to make a difference is debatable
