spark plug
hardo
year: 0
spark plug
Post by hardo »
Hi everyone, my 906 paso does not start too good and hence I would like to replace the spark plugs first. Is it possible to replace them with just removing the big panelings on the side or do I have also to remove the fuel tank? If yes, is there something important to consider? I know that for an expert this is not a big thing to replace spark plugs but the bike is new for me (just bought it a couple of month ago). Thank you and many greetings, hardo :thumbup:
decesaro
Post by decesaro »
Yep you'll have to pull the side panels,dont forget to pull the back side panels first. I would also remove the two tank bolts, It just made it easier to do ,Im sure I could of just used a swivel but I had to pull the tank anyway for what I was doing .
Carefull not to torque to tight :sad:
Hope this helps
