good luck
Rodney
I did wonder on that, do you know which cylinder? I tok the front plug out and turned her with the back wheel, but.......jomo wrote:I just posted this on another question. Worth checking!
just make sure you haven't got hydraulic lock, it's happened to me a few times when my dellorto carb hasn't shut off properly overnight and filled the cylinder with fuel. Same symptoms.
I just put it into 6th gear and turn the rear wheel slowly to drain the cylinder.
jomo
But what???I did wonder on that, do you know which cylinder? I tok the front plug out and turned her with the back wheel, but.......
