Page 2 of 2
Posted: Mon Jan 08, 2007 11:50 am
by jomo
Daryl,
I just bought another 906. Same problem. Someone had been hitting the starter with a hammer and broken the magnets inside.
I sent the starter to a bloke near Gosford N.S.W who glued them back together for $80. Works perfect.
To check, remove the screws on the end of the starter and pay careful attention to the way it comes out.
If you need to remove the starter completely, remove the sub-frame & just pull everything apart to be sure, and rotate the large idler gear that engages the starter until you can see the bolt through the hole. There are 3 holes and they are all off-set.
bad starting motor
Posted: Mon Jan 08, 2007 8:10 pm
by mrinflux
before you replace/rebuild the starting motor, test your starter solenoid. it could be that your starter solenoid is bad rather than your starting motor. you can check this by following the positive lead back from the battery to the starter solenoid. from the starter solenoid there's a second wire going to the starting motor. by-pass the starter solenoid by making a connection, (with a wire or a screwdriver), from the spot where the positive battery lead connects to the starter solenoid and the spot where the second lead exits the starter solenoid going to the starting motor. if the starting motor turns over when you by-pass the starter solenoid than your starting motor is fine and all you need is a new starter solenoid. this is a much simpler and cheaper repair. good luck!
Posted: Mon Jan 08, 2007 9:12 pm
I have voltage at the starter motor when the start button is pressed.
Can`t be the solenoid in this case.
Posted: Mon Jan 08, 2007 11:01 pm
by Daryl
jomo wrote:Daryl,
when you say remove starter completely, and remove subframe, do you mean removing the left hand side, side case or the subframe of the starter itself. If side case do you have to remove all cables etc attached to side case or can you just fold back and drain oil and coolant.
Posted: Tue Jan 30, 2007 11:36 pm
by Daryl
Well finally had the chance to look at the starter motor. Pulled the end off without having to take complete starter motor out. Noticed a lot of grease around brushes, question about this later. Brushes worn out. Ducati dont sell only brushes, complete starter $780. Looked at internet and found that equivalent brushes apparently from ZX 7 kawasaki (part no. 14079-2005 and 2116-1058) however no stock in Melbourne so couldn't compare. Found auto electrician (city auto electrics coburg) with pair of brushes for $30. Had to solder brushes onto original tags. Put starter back together and first press of the starter, that nice ducati sound. So thanks to all for the great information. One question is that when I undid the starter there was pressure build up. Does anyone know if this is normal or is there a motor breather that is not working correctly. Once again thanks. :thumbup: :cool:
