Stand Assembely...Does this look right?
- Desmo_Demon
Re: Stand Assembely...Does this look right?
The one on my '87 Paso 750 does not have the suicide-stand function. I don't know if this is original or not, but it looks like it simply has a longer spring and has that metal plate removed.....
It isn't original, but it seems really simple and effective.Desmo_Demon wrote:The one on my '87 Paso 750 does not have the suicide-stand function. I don't know if this is original or not, but it looks like it simply has a longer spring and has that metal plate removed.....
Most likely measured in BAR. This equates to 145 psi - 159.5 Psi.Pressure: Between 10-11 (forgotten what it`s measured in...).
My local Ducati bike shop tells me that for 900 engines it should usually be around 150 Psi +/- 10% (which equates to 135 Psi - 165 Psi) and that there is no factory specs for dynamic engine compression?
- ducapaso
some bike has kill switch in ground shortcut and this can damage the ignition boxes. Paso's kill switch just breaks positive wire to coils. this may reduce the amount of voltage to coils (see 750 paso F.A.Q) but it's safe for ignitio boxeskirk332 wrote:Do you suggest riding the bike and then when she starts playing up, pull the clutch - switch off the motor - roll to a stop - and pull the plugs and check?(no way to test it, but make the engine run in bad conditions and watch the spark plugs :thumbdown: )
Question, do you switch the motor off with the kill switch or using the ignition key to turn off. I have read something some where that suggests using the key to turn off is better than the kill switch// WHY??
ex...Red "smooth" 753349
the ballast resistors used in some cars (integrated with the coil or external) are there because the ignition system is designed to work satisfactorily when there is less than 12 volts available to it. This happens when the car is being started and the high current draw from the starter motor reduces the terminal voltage at the coil (maybe to 8-9 volts). When the engine is running the terminal voltage is back up to at least 12 (more like 13.6-14.4 as the alternator is generating power). The resistor in the primary coil circuit drops several volts across it so the coil only sees it nominal design voltage of say 9V. In this type of ignition system, if the resistor is bypassed when the engine is running the coil may burn out as the higher voltage will force too much current through the coil.
This was mainly used in older cars with points ignitions. Newer vehicles with electronic ignitions typically don't use ballast resistors with coils.
Thanks for that dave906.
I thought it went something like that but couldn't quite remember as it was a while ago when I last tinkered with older cars like these. I'm guessing the PASO's don't have these resistors in the circuit and so the modified power supply mod for the coils could only be a good thing yer?
Hi Kirk
Yes the power supply mod on this site means that the coils get a more direct supply from the battery, but also that they are not hanging off about 200m of wiring in the loom suffering excessive voltage drop from the current draw due to other loads and dodgy connections thru the ignition switch, kill switch and extra connectors.
Dave
Dave
Hey Dave,
Thanks for that. Have you done the mod yourself and if so was there any noticeable improvement gained? I should imagine if you had any dodgy wiring there, then it would have to improve things a lot. A fairly easy mod though which would alleviate the possibility of that side of things causing a problem I guess.
Kirk
Kirk
