Page 2 of 3
Re: 907 swingarm on 750
Posted: Fri Dec 14, 2007 1:12 pm
by Desmo_Demon
I took some measurements, and using the 750's axle is not possible with a 907 swingarm.
The 907's axle is 350mm long with the non-threaded, center section being 305mm in length. The total length of the stock 750 axle is only 280mm. There is only about a 3mm difference in the internal width of the swingarm between the swingarm's forks, but with the adjuster eccentric's design, the 750 axle is shorter, whereas the 907's axle needs to protrude beyond the outside of the swingarm.
Posted: Sat Dec 15, 2007 4:55 pm
by ducapiero
I found an axle from a monster 600 the diameter is ok 17mm,but the seller says to me that the lenght is 33 cm....
you wrote that i need 35 cm of total axle lenght
....my question is:
he takes wrong measurement?cause the stock monster swingarm seems to me identical in the end part to 907 one....
i hope it should be fit
lamps
Piero
P.S.
do you think chain register of monster 600 will fit???
Posted: Sun Dec 16, 2007 5:11 pm
by Tamburinifan
M600 has 4,5" rear wheel & a steel swing, thererfore the difference
in axle length I think. M900 w alu swing axle would fit as they have the same
rear wheel as 907.
Posted: Tue Dec 18, 2007 2:11 pm
by ducapiero
Posted: Tue Dec 18, 2007 2:27 pm
by Desmo_Demon
ducapiero wrote:i hav to buy one from an St or a 900 monster with alu swingarm....
One from an ST will not work. I know the '98 ST2 (and probably the '97) have a 25mm rear axle. If I were you, contact the guy with the '92 907 rear axle in Canada and offer him $20 for it. You're better off to have the correct axle than to waste your time, and potentially your money, by buying the wrong axle and trying to make it work. It'd be even worse if you had to buy several axles to find one that works...
http://cgi.ebay.com/ebaymotors/92-ducat ... 0092910972
I bet you can get it for $30 USD, shipped to your door.
Posted: Tue Dec 18, 2007 10:08 pm
by nilaus
Hey guys
Found this site with a 17" conversion. Looks neat.
http://alltomingenting.no-ip.info/gallery/new_rear_axle
Regards
Posted: Wed Dec 19, 2007 1:17 pm
by Desmo_Demon
Interesting........I would have a difficult time trusting that M6-M8 bolt to hold the necessary amount of torque required without doing more research, but.....assuming a machinist made that, I'm sure he knew what he was doing. It definitely is interesting.
Posted: Wed Dec 19, 2007 2:19 pm
by nilaus
It is a M8. I have a PDF file of the drawing. I can send it to you. Or you can look at this link
http://alltomingenting.no-ip.info/paso/Excenter
Regards Klaus
Posted: Wed Dec 19, 2007 3:16 pm
by Finnpaso
Seems, that link doesnt function...
Posted: Wed Dec 19, 2007 3:17 pm
by ansim
Finnpaso wrote:Seems, that link doesnt function...
I'll try to fix it.
//Anders
Updated, 2007-12-19, 21:49:
Downlaod the Autocad drawing:
http://alltomingenting.dyndns.info/paso ... center.dwg
There are several free autocad viewers available for download.
I'll try to fix a gif or jpg file later on, after xmas.
Xmas this year will be in Suomi.
//Anders
Posted: Wed Dec 19, 2007 8:09 pm
by nilaus
Hi Anders
Is it you’re PASO on
http://alltomingenting.no-ip.info/gallery/new_rear_axle ? It looks great with conversion. Have you had any issues? What about clearance between the wheel and swing arm?
Klaus
Posted: Wed Dec 19, 2007 9:00 pm
by ansim
Yes,
It's mine.
Clearence are very tight.
Chain alignment was tricky.
The wheel I got was not centered in same way as the Paso.
Needed to make some special spacers.
The excenter is available from a UK manufacturer.
But I had it made localy.
//Anders
Posted: Wed Dec 19, 2007 9:18 pm
by nilaus
What about the depth clearance. I mean does the diameter of the wheel produce a problem. I noticed that the eccentric is at it outer position?
Do you remember where or who in the UK
Klaus
Posted: Wed Dec 19, 2007 9:39 pm
by ansim
Yes,
The wheel dia is a matter. The exenter have to be in back position, otherwise the tire will scrubbing against the front of the swingarm.
I have Pirelli Diablo 160/60 tiresback.
The bike runs more smooth with 17" tires.
//Anders
Posted: Thu Dec 20, 2007 4:50 pm
by ansim
Here is the link to the UK manufacturer,
http://www.swingarm.com/
and a view of the excenter they make,
http://www.swingarm.com/ecc_technical.aspx
Their produced swingarm on a Monster in Sweden,
http://ebbot.net/ducati/m900crsp/gallery/
//Anders
