Page 2 of 3
Re: The Mega Paso Project
Posted: Sun May 25, 2008 9:28 pm
by zap
here the pics of the frame that was on ebay longer time ago
hi,
This was a project from a guy from zwolle (the netherlands) that stopped building because he didn't want to spend more time (or money) in it.
He sold several parts on ebay last year.
I think that the total setup of this bike is quite wrong.
The forks are too long and have only one brakedisc, while mounting a 100 hp engine
ab.
Posted: Mon May 26, 2008 7:12 am
by Mark
Hi All,
Fitting a ST4 engine to a 750 Paso - what a challenge indeed and some of us thrive on challenges!!!
Has anyone thought about building a 2 valve 851cc engine and using a 900SS motor as a basis? Steve Munro from Loudbike embarked on this avenue when he rebuilt a 750 F1 engine:
http://loudbike.blogs.com/photos/f1s_en ... index.html
This approach would probably be less time intensive but may end up being more costly due to the cost associated with building a one-off engine...
Mark
Posted: Thu Jun 26, 2008 11:08 am
by Desmo_Demon
I'm right in the middle of installing the 916 engine into this '88 Paso 750 frame. It is not a direct swap and it looks like I will have to modify the frame a little bit for horizontal head clearance, but it will not compromise the structural integrity of the frame.....especially once I get it rewelded to move the frame rail just a little bit. I've got all of the engine mounting lugs cuts down, but I need to trim the shrouding away from the lower engine mount on the engine cases to clear the lower rear suspension linkage mount on the frame. I'm getting close.
Here is an update on the engine installation with some pictures, so you can see my progress.
http://www.desmodemon.com/mega_paso/engine.html
Posted: Thu Jun 26, 2008 9:52 pm
by DonaldoDuck
Posted: Thu Nov 20, 2008 2:42 pm
by Desmo_Demon
Wow....it's been a while since I've had any time to mess with this project. Since my last post, I've done a valve adjustment and timing belt change on the wife's Monster and performed a bunch of work to other vehicles. This past weekend I did do some more filing on the engine cases to get it to clear the rear suspension mounting point on the frame that was hitting the case, but I have not test-fit the engine, again. I've got six days off starting next Tuesday, and I'm trying to motivate myself to get the engine installed in the frame during those days off from work.....well, work on the Megapaso and pull the swingarm off the wife's GSXR...maybe start the valve adjustment on the 748....change an exhaust gasket on the truck.....do some work to the other ST2.....
Posted: Thu Nov 20, 2008 6:23 pm
by Finnpaso
seems, that You have very similar life, as i have here; too much work with too many bikes !!! This is horrible, because have to do also sometimes something else, that play with Ducatis....
Posted: Sun Nov 23, 2008 5:27 pm
by Desmo_Demon
I spent some more time with it and now have the engine settled into the frame. I had to cut a small section of the frame to clear the horizontal head, but I have the engine bolted into the frame, now. I also see some more potential obstacles to overcome, but those will be later. The next thing I want to do is install the front and rear suspensions before getting the frame rewelded where I had to cut it, so that the frame will look nice and clean and unbutchered, again...
Posted: Sun Nov 23, 2008 5:50 pm
by jcslocum
That motor looks really good in there!!!
So the frame was only cut on the one side to clear the cam? Do you have a picture from the front to see how much interference there is??
So far, so good!
Posted: Sun Nov 23, 2008 6:26 pm
by persempre907
I guess you will need to strenghten the frame to allow it to manage the extra power.
Posted: Sun Nov 23, 2008 7:29 pm
by Finnpaso
We shall see, does front tire hit to front sylinder/head....
Btw. whatkind electrics You have planned to Your project ?????
Posted: Sun Nov 23, 2008 11:55 pm
by Desmo_Demon
jcslocum wrote:So the frame was only cut on the one side to clear the cam? Do you have a picture from the front to see how much interference there is??
Sure.....The belt cover and cam hits the frame fairly easily, and the cross bar in the front interfers with the intake valve cover. I removed the valve cover to get the frame settled down a little bit further.
persempre907 wrote:I guess you will need to strenghten the frame to allow it to manage the extra power.
Yes, it may be necessary.
Finnpaso wrote:We shall see, does front tire hit to front sylinder/head....
The heads on the ST4 are shorter in height than the regular 916 Superbike engine and is named the "Testastretta Basso". They are the same heads that are on the '02 748 and may not cause any clearance issues with the front wheel....These heads were originally designed for the ST4 due to clearance issues with the standard heads and front wheel clearance.
For electronics, I have the complete wiring harness, sensors, ECU computer, coils, headers, and everything else needed from the same bike that the engine came from....Basically, it will be an ST4 shoved into a Paso frame and bodywork.
Posted: Wed Mar 04, 2009 2:21 am
by Desmo_Demon
Posted: Wed Mar 04, 2009 11:27 am
by persempre907
Is the swingarm painted or anodyzed?
Ciao.
Posted: Wed Mar 04, 2009 1:47 pm
by Desmo_Demon
persempre907 wrote:Is the swingarm painted or anodyzed?
It is a modified steel swingarm from an ST2/4, so it is painted. I used a silver color for a GM truck that I found at a local auto paint store.
Posted: Wed Mar 04, 2009 3:11 pm
by Tamburinifan
Will it be 16 or 17" frontwheel?
