Page 2 of 6
Re: Murayama Motors Paso
Posted: Tue Sep 30, 2008 9:27 am
by JWilliam
Your PASO looks fast, too. :thumbup:
Yes Ken San, it will do about 165 mph.
Posted: Thu Oct 02, 2008 1:06 am
by Ken@Murayama-Paso
JWilliam wrote:Yes Ken San, it will do about 165 mph.
165 mph!? incredible speed! :shock:
Is it 750, 906 or other special engine?
My Murayama-Paso(not racer) do about 125mph/8500rpm.
And Weber DCNF is screaming when it do max speed. :twisted:
Posted: Thu Oct 02, 2008 9:29 am
by JWilliam
It is a 906 machine and I have done almost everything I know to make it fast. It will do 120 mph in 4th gear. Went for a ride with other Ducati riders a week ago and a guy with a 996R had trouble keeping up, very funny. The engine has standard crank, rods and cams.
Posted: Thu Oct 02, 2008 9:55 am
never mind, but hard to believe that a bike that normally hardly goes over 210km/h would run 265km/h without huge modifications (considering it`s not in free fall :)
What was done ?
Posted: Thu Oct 02, 2008 10:46 am
by higgy
There is a lot to be had by getting the dcnf setup properly in combination with airbox mods and better exhaust I have been fiddling with mine and I am simply amazed at the difference in power,more on this later............still have a few more things to try
Posted: Thu Oct 02, 2008 10:00 pm
by persempre907
JWilliam wrote:It is a 906 machine and I have done almost everything I know to make it fast. It will do 120 mph in 4th gear. Went for a ride with other Ducati riders a week ago and a guy with a 996R had trouble keeping up, very funny. The engine has standard crank, rods and cams.
Turbo?, NOS?, what the hell did you on the engine to run so fast with stock crank, rods and cams???
Very curious.
Ciao :thumbup:
Posted: Fri Oct 03, 2008 9:32 am
by JWilliam
Very curious.
Ciao :thumbup:
I am of the opinion that factors like valve size, cam lift and rod weight etc are not that important but accurate carburation is, the standard jet settings are typically too lean. The Weber also responds well to positive air pressure feed to the airbox. It has an ITG competition air filter and a 2 into 1 Conti exhaust. Other tricks include heat shielding to the front manifold, running the engine at a lower temperature (which I can do because it is water cooled), 5 teeth off the rear sprocket and doing something to the oil filter.* Equally important is reinforcment of the standard frame around the headstock and steel brake discs on the front(power is nothing without control).
* If you want to know the finer details I can send you a private message.
Posted: Fri Oct 03, 2008 10:51 am
by persempre907
JWilliam wrote: * If you want to know the finer details I can send you a private message.
Many thanks!
I also have 2 in 1 Conti and an high performance filter on my 907.
I don't have a less 5 teeth rear sprocket, but.....
Ciao :thumbup: :thumbup:
Posted: Fri Oct 17, 2008 12:23 pm
by Tamburinifan
Ken, you`ve got pm, kind of urgent.
Posted: Sat Oct 18, 2008 9:23 am
Tamburinifan wrote:Ken, you`ve got pm, kind of urgent.
OK, I checked it.
Posted: Tue Oct 28, 2008 4:48 pm
by Tamburinifan
Really nice article on your Pasos in th Ducati Magazine no 11 magazine!
Too bad I couldn`t read it....
Posted: Wed Oct 29, 2008 2:25 am
Tamburinifan wrote:Really nice article on your Pasos in th Ducati Magazine no 11 magazine!
Oh, you got it in Tokyo?
How was the stay in there, did you find bike stores?
Posted: Wed Oct 29, 2008 2:48 am
by Tamburinifan
Yup, that is the magazine I found, 3 full pages Ken & Murayama!
Didn“t have time f Duc shops, too much work.
Just enjoyed the cool stripped bikes w 1 cyl, semi offroad tires & the long black scooters.
Cool enough.
Posted: Sat Nov 08, 2008 11:57 am
Bevel & Pantah touring in Japan.
http://zoome.jp/ken_works/diary/42/
Posted: Sat Nov 08, 2008 2:05 pm
by Finnpaso
ABSOLUTELY ONE OF BEST EVER SEEN VIDEO CLIPS !!!!!!!! Great work from Japan ! :thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
I am waiting only, what You jap guys think about jap bikes ?????????????? Do they have that "character" ("metal in oil") ???????? :mrgreen: :mrgreen: :mrgreen: :mrgreen: :thumbup:
GREAT !!!!!!!! I am happy again! :mrgreen:
