Page 2 of 2
Re: Bits for attaching side panels to tank
Posted: Sun Oct 05, 2008 8:12 pm
by englishstiv
I am going to see a mate at the weekend who likes to play with lathes and the such like as a hobby and I shall see what he thinks to spending some time making some of these - my problem is that on my bike I have none so can any one post a couple of photo's and maybe a life size diagram or dimensuions on a drawing of these "nipples" so that I can give him an idea. Assuming folk have had theirs knackered like mine I reckon a run of about 100 should suit everyone on the site possibly interested. Assuming it's cost effective for him?
It will also help keep my side panels in situ.
I shall also see if i can get hold of the tank rubbers from my local dealer to help get a tight fit.
Alternatively to save my Mirrors saga I can get them made on an as ordered and paid for basis
Posted: Sun Oct 05, 2008 8:22 pm
by Kurt
Finnpaso wrote:Surely with lathe is very simple to make such parts, but if You can(WANT!) play with Pasos, then You can also make such easy part from metal in Your garrage table... It takes about 30 mins to make such, if U have some basic tools, not lathe.... Take some beers and time goes faster, when U make it!
For sure, no lathe needed, just work with hacksaw, grinding wheel, electric drill ... crude, but effective
Maybe use a "button head" cap screw ... like this:
... and chamfer or round off the bottom edge of the head a little to make it easier to withdraw from the grommet ... and glue a matching nut onto the fairing for attachment ... something like that ... you see, no beer needed!
Posted: Sun Oct 05, 2008 9:32 pm
by englishstiv
Well guys I have just been out inspecting what is left of the lugs on my side panels and it isn't a lot as they have been ground off but what I have found is a load of bits left from my Ikea flat pack furniture bags and there are an several wooden lugs there that look like they can can be shaped to fit and a good few metal studs that can be cut down to do the same.
If any one can come up with some dimensions it would be appreciated.
Posted: Sun Oct 05, 2008 9:46 pm
by persempre907
Tomorrow, I'll post the measures.
Good night
Posted: Mon Oct 06, 2008 1:42 am
by samandkimberly
I'd be happy to make up a few, especially if someone will post dimensions, or loan me a part. I don't even have threaded studs, so I'd make something that either screws onto the stud, or could be stuck right on the fairing where the bolts were gone.
Kurt - that wasn't me at Lars Anderson - I usually make it, but I was competing in the Moto Giro in VT that day. I live in Littleton, MA about 3 mi from Moto Market - do you ever go to Euro Bike night on Thur? If you come by and loan me a stud and buy me 4 grommets, I'll make up 2 studs for you...:-)
Sam
Posted: Mon Oct 06, 2008 12:00 pm
by Kurt
samandkimberly wrote:I'd be happy to make up a few, especially if someone will post dimensions, or loan me a part. I don't even have threaded studs, so I'd make something that either screws onto the stud, or could be stuck right on the fairing where the bolts were gone.
Sam
Hi Sam -- small world indeed. I rarely get to Thursday nights at MotoMarket, what with the wretched traffic at that hour heading out of Boston.
But we should be able to figure out a meeting when I can bring you one of the "bullets." Will add more grommets to my order at Seacoast (will call and give them the CORRECT P/N). I will send you a PM with my ph# and email.
Thanks!
Posted: Mon Oct 06, 2008 8:35 pm
by persempre907
Total height 17 mm.
______
|******| Diameter 10 mm.
| ***| Height. 10 mm./Diameter 8 mm.
I hope you understand.
Let me know.
Posted: Tue Oct 07, 2008 12:36 am
by samandkimberly
persempre907 wrote:Total height 17 mm.
______
Let me know.
That makes perfect sense. But what is the thread sticking out of the panel? It looks like M6, about 15mm - that about right?
Sam
Posted: Tue Oct 07, 2008 9:35 am
by englishstiv
are they all threaded I have been advised by my dealer that they recall they should be lipped nipples that are clasped by the seal. was a bolt later used or is this a case where there are two types.
thank you for the easurements
Posted: Tue Oct 07, 2008 7:41 pm
by ducbertus
Hi Kurt,
if you fail to find the bullets, I can machine them for you. (private machine shop containing a toolroom lathe, 2 tool room grinders, conventional milling machine, dead CNC milling machine, sawing machine, big drill, belt grinder and a pile of tools)
What's the size of the threat in the picture anyway? M8 of bigger?
How many you need? (the lesser the better, means lesser work)
I don't need a drawing as I have fairing parts hanging around incl. the bullet.
let me know.
ducbertus
Posted: Tue Oct 07, 2008 9:34 pm
by Kurt
ducbertus wrote:Hi Kurt,
let me know.
ducbertus
Hi Ducbertus,
Wow, you have quite the set up! The thread on the stud is 6mm (as Sam surmised). I plan to take the panel off soon and measure everything, including the height of the boss that the stud is mounted into. All those dimensions should give us the proper fit to the tank. Also, Sam (who lives not far from me) has also offered to make them up. Maybe we can have a US and a EU supplier, since it sounds like quite a few of these are MIA.
My Duc dealer has ordered the oblong grommets (4) that go into the tank. (Sam: I ordered a set for you, too, at Seacoast.) I am missing all four of the grommets and just two of the bullets. Will come back with more info since others inquiring minds want to know.
... more news as it happens
Posted: Thu Oct 09, 2008 5:37 pm
by andrew_b
I could use a set of these also...rubber bits and bullets.
Once you have your bits could you post a summary of what to ask for and from where?
Andrew
Posted: Thu Oct 09, 2008 6:46 pm
by Kurt
andrew_b wrote:I could use a set of these also...rubber bits and bullets.
Andrew
Hi Andrew, will do! The grommets are en route from Ducati (I hope) as ordered by my dealer, and I've been riding instead of wrenching. Looks like there's enough demand to start making these up.
