body panel alignment
Shelboss
Re: body panel alignment
Post by Shelboss »
What about shimming the tail piece to even up the gap to the side panels?
samandkimberly
Post by samandkimberly »
Done that. The problem is that then the seat back doesn't align, and the whole thing just doesn't look straight if you shim it enough to balance both sides. I took the shims back out. It really doesn't look too bad the way it is. I just want to fully understand why it's that way.
Sam
Shelboss
Post by Shelboss »
Hi Sam, I got my left side panel to fit by putting an 1/8" aluminum spacer between the frame and the taillight assembly. The taillight lens actually lines up better to the tail section and I have a gap between the lens and the side panel :thumbup:
